ADV212  16 bit mode operation
Question asked by fcsstar on Oct 19, 2015
Latest reply on Jan 5, 2016 by DaveD
Hi DaveD, Here is a Urgent Problem in JPEG Encoding by ADV212
Sample Image is consiste of 120x120 pixel and each pixel is 2Byte Grayscale
we want to encode in 2*16bit Mode
so, We set PMODE1 Register, HDATA : 0x18(32bit 2x16-bit Packet Single component)
but the problem is occured..
For example 2-pixel input Data is 0xAABB CCDD(it is amount of 2 pixel)
then, Encoded jp2 output data is 0xAA00CC00 (Decoded in MATLAB, j2c format has same problem)
it seems like ADV212 chopping Lower Byte(LSB) each pixel
additionally, I try to encoding a Sample Data in 4*8bit Mode, It Succesfully operated.
I quess It is not communication interface problem.
let us know somewhat like Register parameter or renewal firmware
======== PARAMETER SETTING =========
       1) HIPI mode
            - sample data 16 bit mode  encode function only
                 encoder firmware  : 2_13_0.sea
            -    register setup
                 direct register
                    BUSMODE    :  0x000A
                    MMODE        :  0x000A
                    PLL_HI           :  0x0008    ( input clock : 25 MHz )
                    PLL_LO          :  0x0005
                    --->     HCLK = 62.5 MHz , JCLOCK = 125 MHz
                indirect register
                    PMODE1     :   0x0418
                    XTOT          :   0x0078
                    YTOT          :   0x0078
                    PMODE2     :   0x0030
                    VMODE      :    0x0012
                    EDMOD0    :    0x0051
                    EDMOD1    :    0x0052
                firmware parameter  encode settings
                   VFORMAT    :  0x04
                   PREC           : 0x0
                   XFORMLEV   : 0x01
                   UNI               : 0x03
                   CBSIZE         : 0x02
                   WKERNEL     :  0x00
                   STALLPAR     : 0x00
                   ATTRTYPE    : 0x00
                   RCTYPE        :  0x01
                   RCVAL          :  0x1c20    ( compress rate : 1 / 4  )
                   J2KPROG      :  0x00
                   PICFG           :  0x00
                   QFACT          : 0x00
                   COD_STYLE  : 0x03
