Petalinux HDMI can`t found on zed
Question asked by huanmolb@163.com on Oct 15, 2015
Latest reply on Oct 19, 2015 by larsc
Hi ,guys ,I`m a newer from high school. I have no exp on this pro.
I follow the wiki HDMI on ZedBoard with Petalinux. | d9 Tech Blog build my project,but I use the linux-xcomm-zynq 4.0 kernel ,only this point is diffrent from the d9,  and my pro can`t found my hdmi ? I put my boot log at the end of my question ,and I cant`t find any error log, so I `m very confused , may any body can help me find the problem ,plz?
Thx ~
Li~~
bootconsole [earlycon0] disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to e0818000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB
Serial Device
e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus
number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Xilinx Zynq CpuIdle Driver started
Driver 'mmcblk' needs updating - please use bus_type
methods
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-arasan e0100000.sdhci: No vmmc regulator found
sdhci-arasan e0100000.sdhci: No vqmmc regulator found
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci]
using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Registering SWP/SWPB emulation handler
/home/li/ZYNQ/adv7511/components/linux-kernel/linux-
xcomm_zynq/drivers/rtc/hctosys.c: unable to open rtc device
(rtc0)
mmc0: new high speed SDHC card at address 1234
mmcblk0: mmc0:1234 SA32G 29.3 GiB
mmcblk0: p1 p2 p3
ALSA device list:
  No soundcards found.
Freeing unused kernel memory: 8056K (c0620000 - c0dfe000)
INIT: version 2.88 booting
mkdir: can't create directory '/run/media/mmcblk0p1': No
such file or directory
mount: mounting /dev/mmcblk0p1 on /run/media/mmcblk0p1
failed: No such file or directory
mkdir: can't create directory '/run/media/mmcblk0p2': No
mount: mounting /dev/mmcblk0p2 on /run/media/mmcblk0p2
mkdir: can't create directory '/run/media/mmcblk0p3': No
mount: mounting /dev/mmcblk0p3 on /run/media/mmcblk0p3
Creating /dev/flash/* device nodes
random: dd urandom read with 1 bits of entropy available
starting Busybox inet Daemon: inetd... done.
Starting uWeb server:
update-rc.d: /etc/init.d/run-postinsts exists during rc.d
purge (continuing)
Removing any system startup links for run-postinsts ...
  /etc/rcS.d/S99run-postinsts
