GNURadio Segmentation Fault with gr-iio
Question asked by richardhob on Oct 8, 2015
Latest reply on Oct 10, 2015 by richardhob
On October 7th, I installed GNURadio on my laptop under Debian 8 using pybombs in an attempt to develop with the FMCOMMS2 and the Zedboard.  The installation of GNURadio and gr-iio went flawlessly, but while running the fmreceiver example that came with the installation there was an error.  The GNURadio return code error was -11.
Using the generated "top_block.py" and pdb, I did a little investigating as to where the issue was being generated.
Breakpoint 1 at ~/pybombs/src/gr-iio/iio-examples/top_block.py:64
(Pdb) r
Error: failed to enable real-time scheduling.
Using Volk machine: avx_64_mmx
> ~/pybombs/src/gr-iio/iio-examples/top_block.py(64)__init__()
-> self.iio_fmcomms2_source_0 = iio.fmcomms2_source("192.168.1.42", fm_station, 1536000, decimation - 1, 20000000, True, True, False, False, 0x20000, True, True, True, "slow_attack", 64.0, "slow_attack", 64.0, "A_BALANCED")
(Pdb) s
--Call--
> ~/target/lib/python2.7/dist-packages/gnuradio/iio/iio_swig.py(162)make()
-> def make(*args, **kwargs):
(Pdb) n
> ~/target/lib/python2.7/dist-packages/gnuradio/iio/iio_swig.py(170)make()
-> return _iio_swig.fmcomms2_source_make(*args, **kwargs)
(Pdb) s
Segmentation fault
I would be greatly appreciative of any help or solutions!  Thank you ahead of time!
