Simple GPI expansion
Question asked by ChristianH on Oct 8, 2015
Latest reply on Oct 8, 2015 by AlClark
I'm using the ADSP-21489 and need more GPIs (~15).
All DAI and DPI pins are already used by other functions, also FLAG0-3.
So I tried to map FLAG4-15 to AMI interface (DATA0-7, ADDR0-7).
Here it seems that the internal pull-up (ipu) resistor brings the flag pins to a HIGH state.
For electronical reasons it is not preferred to use an external pull-down below 20k (which would be necessary if I understood it correctly).
One option is to use AMI DATA0-15 but reading from them needs some more DSP cycles (setting all wait states etc. to the lowest possible option) which I would like to avoid.
Another option is to use PDAP port on AMI ADDR4-23. Here it seems that the ipu are not active because the level is LOW.
Can anybody send me a simple example how to read levels from via PDAP maybe without the need to set any clocking stuff on PDAP?
Any ideas welcome!
Thanks!
Christian
