ADV8005 is very sensitive to temperature at the 4K resolution
Question asked by epwujm on Oct 7, 2015
Latest reply on Oct 14, 2015 by epwujm
  I found the ADV8005 is very sensitive to temperature at the 4K resolution
Now I enable the TX2 output at the 4K resolution,it can output the signal at beginning,but 1-2 minutes later,there are some noise at the output signal,and then the signal is worse and worse,and then it loss。If I use the heat sinks and use the fan blow the device and let it cool,the output signal display again and stable。The temperature will be up to about over 65 °C  when I take out the fan ,and when I blow it the temperature will be about 30 °C .
With or without the fan,the 2K or under resolution outputs are all stable。So I think the high temperature affects the TX phase lock loop at the 4K output。And now because limited by the space,I can't use the fan in my design.
Are there some registers use for the PLL circuits? How can I set them and let it not to be sensitive to the temperature?
