Issues using fcomms1 on ZC706
Question asked by McG on Sep 24, 2015
Latest reply on Sep 30, 2015 by rejeesh
Hi all,
I have a system composed by ad-fcomms1-ebz and Xilinx ZC706.
In order to test the system I used, for the hardware, the hdl-master taken here analogdevicesinc/hdl · GitHub and, for the software, the no-OS packages found here analogdevicesinc/no-OS · GitHub.
Using Vivado 2014.4.1 under linux os, for hdl I built the system without problems using the shell command:
>> make fmcomms1.zc706
For the software, I used the main.c contained in the no-OS/fmcomms1/Common. The compilation was ok both for hardware and software.
The problem is the in the plot of signals coming from ADC and stored in the ILA.
1. Why the probe1 is composed by 64-bits while the ADC should generate 4 14-bits sine waves (as shown here: AD-FMCOMMS1-EBZ Quick Start Guide on Xilinx FPGA Boards Without OS [Analog Devices Wiki])?
2. Deleting the bit 15 and 16 of each 16-bits group I obtain the followig result:
If I magnify the details obtain:
The configuration of signal representation is signed. I didn't change anything both for hardware and software original settings (I changed just the receiver gain with 1). So I don't know why I obtain this behaviour. The consolle output of SDK is the following:
Running XCOMM Test Program
Initializing XCOMM I2C...
XCOMM Init I2C OK!
Getting XCOMM Revision...
Board Version: Analog Devices, FMC Comms 1, 01009, AD-FMCOMMS1-EBZ, PCB Rev.C, BOM Rev.0
Initializing XCOMM Components...
XCOMM Init OK!
Initializing the Rx path...
XCOMM Rx Init OK!
Initializing the Tx path...
XCOMM Tx Init OK!
ADC sampling rate [Hz]: 122880000
DAC sampling rate [Hz]: 122880000
DAC available interpolation frequencies [Hz]: 122880000 245760000 491520000 983040000
DAC available center shift frequencies [Hz]: 0
Testing the ADC communication...
adc_test: adc_clock(122.880MHz)
adc_test: mode( 1), format( 1)
adc_test: mode( 2), format( 1)
adc_test: mode( 3), format( 1)
adc_test: mode( 4), format( 1)
adc_test: mode( 5), format( 1)
adc_test: mode( 6), format( 1)
adc_test: mode( 7), format( 1)
ADC test complete.
Testing the DAC communication...
dac_setup: dac_clock(122.882MHz)
dac_sed: s0(0x0000AAAA), s1(0x00000000)
dac_sed: s0(0x00005555), s1(0x00000000)
dac_sed: s0(0xAAAA0000), s1(0x00000000)
dac_sed: s0(0x55550000), s1(0x00000000)
dac_sed: s0(0x00000000), s1(0x0000AAAA)
dac_sed: s0(0x00000000), s1(0x00005555)
dac_sed: s0(0x00000000), s1(0xAAAA0000)
dac_sed: s0(0x00000000), s1(0x55550000)
dac_sed: s0(0x00000000), s1(0x00000000)
dac_sed: s0(0xAAAAAAAA), s1(0x55555555)
dac_sed: s0(0x55555555), s1(0xAAAAAAAA)
DAC test complete.
Setting the VGA gain to: 0.1 dB
Actual set VGA gain: 4.500 dB
Setting the Rx frequency to: 0002400
Actual set Rx frequency: 0002400
Setting the Tx frequency to: 0002400
Actual set Tx frequency: 0002400
Setting up the DDS...
DDS setup complete.
Reading data from air...
Read data from air complete.
Finished XCOMM Test Program
Regards
RF
