ad9361 device driver trouble
Question asked by qianshuyuan on Sep 22, 2015
Latest reply on Sep 29, 2015 by qianshuyuan
first I config fir
then I enable fir
the trouble are as follows
<ces/iio:device0# cat /root/share/filter.txt > filter_fir_config
root@zynq:/sys/bus/iio/devices/iio:device0# cat filter_fir_config
FIR Rx: 128,2 Tx: 0,0
root@zynq:/sys/bus/iio/devices/iio:device0# cat in_voltage_filter_fir_en
0
root@zynq:/sys/bus/iio/devices/iio:device0# echo 1 > in_voltage_filter_fir_en
Unable to handle kernel paging request at virtual address 00004000
pgd = dca80000
[00004000] *pgd=1cb40831, *pte=00000000, *ppte=00000000
Internal error: Oops - BUG: 17 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 878 Comm: sh Not tainted 4.0.0-xilinx #4
Hardware name: Xilinx Zynq Platform
task: ddff9580 ti: dcbc2000 task.ti: dcbc2000
PC is at ad9361_dig_tune+0x4c/0x930
LR is at 0xdcadcac0
pc : [<c03a9044>]    lr : [<dcadcac0>]    psr: a00f0013
sp : dcbc3da8  ip : 00000000  fp : 00000000
r10: dcbc3ec4  r9 : 00000010  r8 : 00000000
r7 : ddc7e010  r6 : 00004000  r5 : dcadc800  r4 : dca9a2c0
r3 : dcbc3e2c  r2 : 03a98000  r1 : 02625a00  r0 : 017d7840
Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 18c5387d  Table: 1ca8004a  DAC: 00000015
Process sh (pid: 878, stack limit = 0xdcbc2210)
Stack: (0xdcbc3da8 to 0xdcbc4000)
3da0:                   00000000 00000000 00000000 00000000 00000000 00000000
3dc0: 00000000 00000000 dcadcac0 00000000 00000000 00000000 dcbc3d94 dcbc3d94
3de0: dca34600 00000000 c02bd6a4 00000000 00000003 00000003 00000000 dcbc3dfc
3e00: dcbc3dfc 00000000 00000000 dca34600 00800000 000000dc 00000000 dcbc3eac
3e20: dcbc3ec4 c039ead0 00000000 017d7840 02625a00 03a98000 00000002 dca34600
3e40: 00000000 dca9a2c0 00001194 00000001 dca9a2d4 00000000 dcbc3eac dcbc3ec4
3e60: 00000000 c03a3ca8 00000000 dcbc3e98 dca9a2c0 dca34600 00000000 dca9a1b0
3e80: dcbc3eb0 dcbc2000 00000002 c03a3f4c dcbc3eb0 dcbc3ef0 3a980000 1d4c0000
3ea0: 0ea60000 07530000 03a98000 01d4c000 3a980000 0ea60000 07530000 03a98000
3ec0: 01d4c000 01d4c000 dca9a010 00000000 00001444 dca9a1b0 dca9a2c0 c03a430c
3ee0: be995a7c c00c3784 00000041 0000081f ffffffff 019b4198 00000002 de84d500
3f00: dcb3da88 dcb3db28 dcbc3f88 dcbc2000 de84d58c c026ab80 00000002 c0105c8c
3f20: c0105c4c de84d580 de84d500 dcb3da88 00000002 c01050d4 00000000 00000000
3f40: 00000002 dddf2400 00000002 000de408 dcbc3f88 c000de24 00000000 c00b750c
3f60: dddf2400 000de408 00000002 dddf2400 dddf2400 00000002 000de408 c000de24
3f80: 00000000 c00b77ac 00000000 00000000 00000002 00000002 000de408 b6e85a88
3fa0: 00000004 c000dca0 00000002 000de408 00000001 000de408 00000002 00000000
3fc0: 00000002 000de408 b6e85a88 00000004 00000002 00000002 000de408 00000000
3fe0: 00000000 be995994 b6dbc7e4 b6e0f6ec 60070010 00000001 00000000 00000000
[<c03a9044>] (ad9361_dig_tune) from [<c03a3ca8>] (ad9361_set_trx_clock_chain+0x1a0/0x204)
[<c03a3ca8>] (ad9361_set_trx_clock_chain) from [<c03a3f4c>] (ad9361_validate_enable_fir+0x240/0x2d0)
[<c03a3f4c>] (ad9361_validate_enable_fir) from [<c03a430c>] (ad9361_phy_store+0x330/0x694)
[<c03a430c>] (ad9361_phy_store) from [<c026ab80>] (dev_attr_store+0x18/0x24)
[<c026ab80>] (dev_attr_store) from [<c0105c8c>] (sysfs_kf_write+0x40/0x4c)
[<c0105c8c>] (sysfs_kf_write) from [<c01050d4>] (kernfs_fop_write+0x120/0x174)
[<c01050d4>] (kernfs_fop_write) from [<c00b750c>] (vfs_write+0xbc/0x170)
[<c00b750c>] (vfs_write) from [<c00b77ac>] (SyS_write+0x40/0x78)
[<c00b77ac>] (SyS_write) from [<c000dca0>] (ret_fast_syscall+0x0/0x34)
Code: e285ed0b e58de020 e595c300 e28c6901 (e5966000)
---[ end trace 1a77fa981350e61c ]---
_____       _           _      _
| ___ \     | |         | |    (_)
| |_/ / ___ | |_   __ _ | |     _  _ __   _   _ __  __
|  __/ / _ \| __| / _` || |    | || '_ \ | | | |\ \/ /
| |   |  __/| |_ | (_| || |____| || | | || |_| | >  <
\_|    \___| \__| \__,_|\_____/|_||_| |_| \__,_|/_/\_\
PetaLinux v2013.10 (Yocto 1.4) zynq ttyPS0
zynq login: root
Password:
login[885]: root login  on `ttyPS0'
