UserExceptionHandler called when writing to memory block
Question asked by MattZ on Apr 27, 2011
Latest reply on Apr 28, 2011 by MattZ
Hi All,
I came across a problem when trying to assign a 32 bit value to two sequential 16 bit memory blocks. I'm using a BF537 and used the code:
*((T_UINT32*)&MyMemBlock[1])               = (T_UINT32)0xAAAABBBB;
In this example, MyMemBlock was declared as:
T_UINT16 MyMemBlock[50];
I would expect that the value 0xBBBB be copied to MyMemBlock[1] and 0xAAAA be copied to MyMemBlock[2].
The disassebmly viewer shows the following:
P0.L = 0x1cde ;
P0.H = 0xff90 ;
R1 = -17477 ( X ) ;
R1.H = -21846 ;
[ P0 ] = R1 ;
I think this make sense. 0xff9001cde is the correct address for MyMemBlock[1]. However, UserExceptionHandler keeps getting called in the final assembly operation [ P0 ] = R1 ;
I've also noticed that *((T_UINT32*)&MyMemBlock[2])      = (T_UINT32)0xAAAABBBB; works. <--note the 2 index in MeMemBlock.
Does anyone have any ideas how I can debug this? One thought I had is that MyMemBlock[1] is not on a 32bit boundary inside MyMemBlock but MyMemBlock[2] is. Would this be the problem? Is this documented anywhere?
thanks in advance
-Matt
