ADXL345 Basics understanding for newbie
Question asked by prakash2025 on Sep 17, 2015
Latest reply on Sep 18, 2015 by prakash2025
Hi all
i am using ADXL345 accelerometer. I am trying to evaluate the features available in the Acceleometer. I have few queries since i am newbie to this.
1. First i tried to read the output data registers value from register 0x32 as 6 bytes continuously after configuring the power ctl(0x2d)
   register in to measure mode and i can able to read the data. Also if i am trying to read the data from register 0x32 as 6 bytes          continuously  without configuring power ctl register into measure mode also i can get the same values, why is it so?
2. I have received the values from different direction and i mapped the received values against the X,Y,Z axis based on the MSB bit.
   Can any one confirm whether my mapping is correct?
AxisAssumption (received)Actual(based on MSB bit)
X+
X = 0xFF << 8 + 0x1A
Y = 0x00 <<  8 + 0x0E
Z = 0x00 << 8 + 0x00
X = 0x01 << 8 + 0x08
Y = 0x00 <<  8 + 0x08
Z = 0x00 << 8 + 0x19
X-
Y+
X = 0x0D << 8 + 0x00
Y = 0xFF <<  8 + 0xF4
Z = 0xFF << 8 + 0x20
X = 0x00 << 8 + 0x09
Y = 0x00 <<  8 + 0x0A
Z = 0xFF << 8 + 0x1D
Y-
X = 0x00 << 8 + 0x19
Y = 0xFF <<  8 + 0xFF
Z = 0x01 << 8 + 0x0C
Z+
Z-
3. I have tried for single tap detection as follows
  set DUR register(0x21) to 0x10 (10ms)
  set TAP_AXES register(0x2A) to 0x07
  set THRESH_TAP register(0x1D) to 0x30
  set INT_ENABLE register (0x2E) to 0x40
  set POWER_CTL  register (0x2D) to 0x08
   but the tap detection interrupt bit is not set in INT_SOURCE (0x30) register. Could any one help me guide for solving this issue.
4. I have tried for activity and inactivity event as follows (after clearing whwtever the register i have set for tap detection)
   for that case also the corresponding  interrupt bit are not set.
  set ACT_INACT_CTL register(0x27) to 0x77
  set THRESH_ACT register(0x24) to 0x10
  set THRESH_INACT register(0x25) to 0x10
  set THRESH_INACT register(0x26) to 0x05
  set INT_ENABLE register (0x2E) to 0x18
Thanks in advance
