Compiling problems with bfin-uclinux-gcc
Question asked by Jorge68 on Sep 17, 2015
Latest reply on Sep 30, 2015 by Aaronwu
Hi everybody
I have some troubles with bfin-uclinux-gcc.
When I try to compile a program to configure GPIOs or another peripherals, I put:
bfin-uclinux-gcc -Wl,-elf2flt example.c -o example
I don't know if the GPIOs are not properly configured, but I'm still learning. However, it doesn't found the files.
#define CONFIG_BF537
#include <mach/cdefBF537.h>
#define SSYNC asm("ssync;")
int main()
    *pPORTH_FER = 0x0000; //El puerto H como GPIO
    SSYNC;
    *pPORTHIO_DIR = 0x8000; // El puerto H como Salida
    SSYNC;
    while (1)
          *pPORTHIO = 0xFFFF; //Todo el puerto en Alto
          SSYNC;
          delayMS(500);
          *pPORTHIO = 0x0000;
          SSYNC;
          delayMS(500);
Compiler's output:
example.c:3:28: error: mach/cdefBF537.h: No such file or directory
example.c: In function ‘main’:
example.c:10: error: ‘pPORTH_FER’ undeclared (first use in this function)
example.c:10: error: (Each undeclared identifier is reported only once
example.c:10: error: for each function it appears in.)
example.c:12: error: ‘pPORTHIO_DIR’ undeclared (first use in this function)
example.c:16: error: ‘pPORTHIO’ undeclared (first use in this function)
I'm new using microprocessors. I'm using uClinux-dist-2009R1.1-RC4 and a BF537.
I hope you can help me please.
Thank you.
Regards
