Migrating vc707&ad6676 Microblaze desgin to kc705_ad6676
Question asked by -2dbc on Sep 16, 2015
Latest reply on Jan 26, 2016 by -2dbc
I want to fit your vc707_ad6676evb_2015_R1_PRE.zip Microblaze design to kc705.
Simply, I want to plot signals on IIO-Oscilloscope over ethernet.
Actually, You dont have to kc705&ad6676 microblaze design.
I modified your vc707&ad6676 hdl project to fit kc705. I generated bit stream and programmed kc705 with it.
I used no-OS/ad6676-ebz software drivers(master branch) and I could not see any problem.(console out is attached)
I searched in your ad6676 no-OS driver codes and I could no see any word related with vc707.
Starting from this point, I decided to use your simpleImage.vc707_ad6676evb(extracted from vc707_ad6676evb_2015_R1_PRE.zip) with my new generated kc705&ad6676 bit file.
And I used your run.tcl script.
Because If your ad6676 driver codes doesn't contain vc707 related settings, I could be use your simpleImage.vc707_ad6676evb for kc705(to my understanding)
Predictably, It doesn't work.
I have also ad9467. With using same setup:
I plug AD9467 to KC705 LPC; ethernet connection is OK and IIO-Oscilloscope works fine.
I unplug AD9467 and plug AD6676; ethernet connection is down.
I can see 192.168.2.2(default IP) on LCD(kc705&AD6676 setup is attached).
I perform ifconfig on target terminal, It says:
eth0 is down, I force eth0 to up, and this causes an exception(dmesg result is attached):
WARNING: CPU: 0 PID: 100 at drivers/net/ethernet/xilinx/xilinx_axienet_mdio.c:26 axienet_mdio_wait_until_ready+0x60/0x90()
Modules linked in:
CPU: 0 PID: 100 Comm: ifconfig Tainted: G        W      3.19.0-gef29f1f #7
Kernel Stack:
ac24bcdc: 8000a2bc .....
I have an experience about linux driver development on Ubuntu, I made some driver modifications for ML605 linux driver, but I'm a newbie in microblaze and your linux drivers.
Please lead me, How can I fit your vc707&ad66 microblaze design to my kc705&ad6676 setup?
Thanks a lot.
