Getting strange valors from ADT7320 (same in ADT7310)
Question asked by HFreitas on Sep 11, 2015
Latest reply on Oct 8, 2015 by Lluis
I'm using your temperature sensor ADT7320 in a project but i'm getting wrong data (the same is true for ADT7310).
The circuit used is in Figure 14 (Typical SPI Interface Connection) of the sensor datasheet, where the microcontroller is an Arduino Uno.
The configuration register (0x01) is set to work in continuous mode & 16 bits (0x80):
And this is what i get when i read the temperature register (0x02):
The room temperature read with a thermocouple is approximately 24 ° C. When i heal a little bit the sensor i'm getting strange data:
Resuming how the program works:
Setup:
-> Start SPI(CPOL = 1 ; CPHA = 0)
-> CS UP
-> Delay 300 ms
-> CS LOW
-> Sending 32 bits of '1'
-> CS HIGH
Loop:
-> CS LOW
-> Send: 0x08
-> Send: 0x80
-> CS HIGH
-> Delay 300 ms
-> CS LOW
-> Send: 0x50
-> Receive MSB while sending 0xFF
-> Receive LSB while sending 0xFF
-> CS HIGH
-> Convert the data.
-> Display data.
-> Delay 300 ms
With a supply of 3.3V i'm getting this (while heating a little bit):
MSB (BIN, HEX, DEC): 1100 - C - 12
LSB (BIN, HEX, DEC): 10100110 - A6 - 166
DATA (BIN, HEX, DEC): 110010100110 - CA6 - 3238
Temperature = 25.26 ºC
LSB (BIN, HEX, DEC): 10110011 - B3 - 179
DATA (BIN, HEX, DEC): 110010110011 - CB3 - 3251
Temperature = 25.36 ºC
(the problem)
MSB (BIN, HEX, DEC): 110100 - 34 - 52
LSB (BIN, HEX, DEC): 110100 - 34 - 52
DATA (BIN, HEX, DEC): 11010000110100 - 3434 - 13364
Temperature = 104.24 ºC
MSB (BIN, HEX, DEC): 1000000 - 40 - 64
LSB (BIN, HEX, DEC): 0 - 0 - 0
DATA (BIN, HEX, DEC): 100000000000000 - 4000 - 16384
Temperature = 127.80 ºC
With a supply of 5V i'm getting this (while heating a little bit):
MSB (BIN, HEX, DEC): 1001 - 9 - 9
LSB (BIN, HEX, DEC): 1111010 - 7A - 122
DATA (BIN, HEX, DEC): 100101111010 - 97A - 2426
Temperature = 18.92 ºC
LSB (BIN, HEX, DEC): 11011100 - DC - 220
DATA (BIN, HEX, DEC): 110011011100 - CDC - 3292
Temperature = 19.53 ºC
(the problem)
MSB (BIN, HEX, DEC): 11010 - 1A - 26
LSB (BIN, HEX, DEC): 1001000 - 48 - 72
DATA (BIN, HEX, DEC): 1101001001000 - 1A48 - 6728
Temperature = 52.48 ºC
LSB (BIN, HEX, DEC): 111100 - 3C - 60
DATA (BIN, HEX, DEC): 1101000111100 - 1A3C - 6716
Temperature = 52.38 ºC
With this data can you help me to figured out what is the problem? Thanks.
