Is there a simple driver example taking advantage of the AXI DMAC?
Question asked by EdwardK on Sep 9, 2015
Latest reply on Oct 9, 2015 by larsc
I have a few custom peripherals in PL for which such a generic driver would be handy and help solve a barrier to entry that I keep running into repeatedly. Basically, I have a custom communication bus and have HDL handling the PHY access. What I am missing is how to get data to and fro Linux user space easily.
a) The following setup is what I envision.
1) # iio bus
set axi_iio_tx_dma [create_bd_cell -type ip -vlnv analog.com:user:axi_dmac:1.0 axi_iio_tx_dma]
set_property -dict [list CONFIG.C_DMA_TYPE_SRC {0}] $axi_iio_tx_dma
set_property -dict [list CONFIG.C_DMA_TYPE_DEST {1}] $axi_iio_tx_dma
set_property -dict [list CONFIG.C_FIFO_SIZE {16}] $axi_iio_tx_dma
set_property -dict [list CONFIG.C_2D_TRANSFER {0}] $axi_iio_tx_dma
set_property -dict [list CONFIG.C_CYCLIC {0}] $axi_iio_tx_dma
set_property -dict [list CONFIG.C_AXI_SLICE_DEST {1}] $axi_iio_tx_dma
set_property -dict [list CONFIG.C_AXI_SLICE_SRC {1}]  $axi_iio_tx_dma
set_property -dict [list CONFIG.C_DMA_DATA_WIDTH_DEST {64}] $axi_iio_tx_dma
set axi_iio_rx_dma [create_bd_cell -type ip -vlnv analog.com:user:axi_dmac:1.0 axi_iio_rx_dma]
set_property -dict [list CONFIG.C_DMA_TYPE_SRC {1}] $axi_iio_rx_dma
set_property -dict [list CONFIG.C_DMA_TYPE_DEST {0}] $axi_iio_rx_dma
set_property -dict [list CONFIG.C_FIFO_SIZE {16}] $axi_iio_rx_dma
set_property -dict [list CONFIG.C_2D_TRANSFER {0}] $axi_iio_rx_dma
set_property -dict [list CONFIG.C_CYCLIC {0}] $axi_iio_rx_dma
set_property -dict [list CONFIG.C_AXI_SLICE_DEST {1}] $axi_iio_rx_dma
set_property -dict [list CONFIG.C_AXI_SLICE_SRC {1}]  $axi_iio_rx_dma
set_property -dict [list CONFIG.C_DMA_DATA_WIDTH_DEST {64}] $axi_iio_rx_dma
ad_mem_hp1_interconnect sys_200m_clk sys_ps7/S_AXI_HP1
ad_mem_hp1_interconnect sys_200m_clk axi_iio_tx_dma/m_src_axi
ad_mem_hp1_interconnect sys_200m_clk axi_iio_rx_dma/m_dest_axi
2) Initial test connect axi_iio_tx_dma/m_axis to axi_iio_rx_dma/s_axis for the loopback.
3) Then connect axi_iio_tx_dma/m_axis to custom_dev/s_axis and axi_iio_rx_dma/s_axis to custom_dev/m_axis.
4) DTSI entries
dma: dma@7c820000 {
  compatible = "adi,axi-dmac-1.00.a";
  reg = <0x7c420000 0x10000>;
  interrupts = <0 57 0>;
  clocks = <&clkc 16>;
  #dma-cells = <1>;
  dma-channel {
  reg = <0>;
  adi,source-bus-width = <64>;
  adi,source-bus-type = <ADI_AXI_DMAC_TYPE_MM_AXI>;
  adi,destination-bus-width = <64>;
  adi,destination-bus-type = <AXI_DMAC_BUS_TYPE_AXI_STREAM>;
dma: dma@7c920000 {
  #dma-cells = <1>;
  dma-channel {
  reg = <0>;
  adi,source-bus-type = <AXI_DMAC_BUS_TYPE_AXI_STREAM>;
  adi,destination-bus-type = <ADI_AXI_DMAC_TYPE_MM_AXI>;
b) What I need is a simple client driver that uses dma-axi-dmac to create a simple IIO rw device that allows checking if there is data via sysfs along with buffer enable & length. I imagine full duplex should not be an issue.
c) This is is all from me looking at what is there but not having much experience with kernel programming. I am I making this way more difficult that it should be? I really would like to avoid using mmap from user land as most folks do and I believe this small piece would be handy to the community as a whole. Maybe in the future, the axi_dmac can add t_dest and then one could use a TX and RX DMA attached to and AXIS interconnect for endless possibilities.
d) I am now looking at the examples but frankly I feel like a middle school student looking at differential equations
Edward
larscmhennerich
