AD9467 ethernet connection problem
Question asked by -2dbc on Sep 5, 2015
Latest reply on Sep 8, 2015 by -2dbc
Hi all,
I have AD9467 and KC705 dev. board. I'm using win7 with cygwin(for linux style make calls.)
I generated bitstream by using reference design hdl codes.(First by using vivado 2014.4.1 and later I upgraded it to vivado 2015.2)
I made required changings on AD9467 for using internal clock.
I programmed FPGA.
I'm also using no-OS software.
I executed your SDK demo and I saw uart results to my console.
I also executed ILA in reference design and I saw signal changings When I changed the signal frequency on signal generator.
I have two questions about AD9467 reference design:
1-) ILA ok, uart connection ok but I could not connect via Ethernet. I tried to find correct IP configuration but I could not find it.
Some documents say "Board's IP is 192.168.1.10 and You have to use 192.168.1.100",
xemaclite_ping_reply_example say "The local IP address is set to 172.16.63.121"
I tried both of them; Windows sends packet, but It can not receive any packets.
I read a post in your forum. "If you are in trouble about ethernet connection, You can use DHCP enabled network."
I used my internet modem for this purpose, I disabled all firewalls e.t.c. and tried to connect board but result is same.
I tried IIO Oscilloscope for connecting over ethernet but I didnt worked also.
How can I connect over ethernet, Please help me.
2-) I monitored signal changings on vivado's ILA section. Although I feed AD9467 with sinus , I could not monitor pure sinus on ILA.
I know ILA has 32 bits instead of ADC's 16 bit and there are some additional purposes. For example It aims to support high frequecies.
There is a FIFO before it...
My question is simple. Is it possible to monitor pure sinus on this ILA. For example "Yes, You can use  1 to 16 bits for this purpose" or something else...
Thanks in advance.
