Test RX FMCOMMS2 (No-os)
Question asked by sangnt11 on Sep 2, 2015
Latest reply on Sep 2, 2015 by mhennerich
Dear!
I want to test RX port of IC AD9361 in FMCOMMS2 platform.
I using " AD9361 No-OS API " to config.
However, I config some case, it does not work.
Case 1:
     change data_port_loop_test_enable from "1" to "0" in file ad9361.h
#define DATA_PORT_LOOP_TEST_ENABLE     (1 << 0) /* Data Port Loop Test Enable */
Case 2:
     change from "ad9361_bist_loopback(phy, 1);" to "ad9361_bist_loopback(phy, 0);" in file ad9361_conv.c (line 403).
That disable ad9361_bist_loopback.
Case 3:
     change function ad9361_bist_loopback in file ad9361.c.
int32_t ad9361_bist_loopback(struct ad9361_rf_phy *phy, int32_t mode)
  uint32_t sp_hd, reg;
  dev_dbg(&phy->spi->dev, "%s: mode %"PRId32, __func__, mode);
  reg = ad9361_spi_read(phy->spi, REG_OBSERVE_CONFIG);
  phy->bist_loopback_mode = mode;
  switch (mode) {
  case 0:
  ad9361_hdl_loopback(phy, false);
  reg &= ~(DATA_PORT_SP_HD_LOOP_TEST_OE |
  DATA_PORT_LOOP_TEST_ENABLE);
  return ad9361_spi_write(phy->spi, REG_OBSERVE_CONFIG, reg);
  case 1:
  /* loopback (AD9361 internal) TX->RX */
  sp_hd = ad9361_spi_read(phy->spi, REG_PARALLEL_PORT_CONF_3);
  if ((sp_hd & SINGLE_PORT_MODE) && (sp_hd & HALF_DUPLEX_MODE))
  reg |= DATA_PORT_SP_HD_LOOP_TEST_OE;
  else
  reg &= ~DATA_PORT_SP_HD_LOOP_TEST_OE;
  reg |= DATA_PORT_LOOP_TEST_ENABLE;
  case 2:
  /* loopback (FPGA internal) RX->TX */
  ad9361_hdl_loopback(phy, true);
  default:
  return -EINVAL;
That disable loopback in all case.
The script: bandwidth 5MHz, system_clock = 15.36MHz (2 channel).
When I change design, all of case, that are faulty:
- clock change from 15.36MHz to 61.44MHz.
- ad9361_init error.
- don't connect SMA rx port, output of AD9361 core have data (using ILA to catch chan_data, chan_valid, chan_enable in block design).
- Amplitude of adc_signal (RX) = -16dm of dac_signal (TX).
SAMPL CLK: 61440000 tuning: TX
  0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
0:# # # # # # # # # # # # # # # #
1:# # # # # # # # # # # # # # # #
ad9361_dig_tune: Tuning TX FAILED!
ad9361_init : AD9361 initialization error
I want to config to test RX port. For example, using 2 FMCOMMS2 platform, one platform to tranfer data, one platfrom receive data, 2 platform are connected by SMA connector.
Thanks and best regard.
Tien-Sang Nguyen.
