ADIS16210 angle error problem
Question asked by perb on Aug 27, 2015
Latest reply on Sep 22, 2015 by NevadaMark
We have an ADIS16210 mounted in an instrument that moves in a circle as seen in the picture. The sensor is represented by the box to the right at the top. The distance d is 240 and r is 400 mm. The gravity axis is along r and the horisontal axis is, i.e. this is just like a weel on a car. The ADIS is not mounted perfectly aligned, a few degrees off is likely.
The z-axis of the ADIS should show the same angles as those of the circle. We measure the angle with two other inclinometers and see deviations by a few degrees.
The app note AN-1057 "Using Accelerometers" discusses deviations caused by misalignments that causes problems like this.
We have tried to use the calibration procedure described but without success.
Any ideas are welcome.
