ADV212 compression rate
Question asked by chengyulan2008@sina.com on Aug 25, 2015
Latest reply on Aug 26, 2015 by DaveD
By using the single-chip  JPEC2000  codes (ADV212), a real-time compression system is presented for high resolution image.
ADV212 Firmware Parameter Encode Settings
Name
Parameter Description
Bytes
Settings
1
VFORMAT
Video Standard
1
Custom-specific :0X04
2
PREC
Precision
1
12bits :0X02
3
XFORMLEV
Number of Wavelet Transform
1
5 levels of transform :0X05
4
UNI
Component Polarity
1
Unipolar C, Unipolar Y :0X03
5
CBSIZE
Code Block Dimensions
1
128*32:0X03
6
WKERNEL
Wavelet Kernel
1
Irreversible 9*7:0X00
7
STALLPAR
Skip Fields in Encode Mode
1
Capture all fields:0X00
8
ATTRTYPE
Attribute Data Output Format
1
Do not output attribute data:0X00
9
RCTYPE
Rate Control Algorithm
1
Within 5% of RCVAL:0X01
10
RCVAL
Target Size or Quality Factor
3
XTOT * YTOT * PRES / Rate / 8
11
J2KPROG
JPEG2000 Progression Style
1
LRCP :0X00
12
PICFG
Pixel Interface
1
0X0F
13
QFACT
Quantization Factor
1
256/256:0X00
14
COD_STYLE
Output Code Stream Format
1
0X01
The compression rate is 4, XTOT is 2048,YTOT is 180,so RCVAL= XTOT * YTOT * PRES / Rate / 8=2048*180*12/4/8.
Issue:
If the input image source is random-data,the result of compression rate is 4,but if the input image source is correlative image source,the result of compression rate far greater than 4.Why?
Why the result of compression rate is variational,not fixed(RCVAL= XTOT * YTOT * PRES / Rate / 8=2048*180*12/4/8)?
