ZedBoard ADV7511 can not display
Question asked by cenjd on Aug 17, 2015
Latest reply on Aug 22, 2015 by cenjd
hello!
      I am now building a 1080P HDMI display project on zedbord according to the wiki ADV7511 Xilinx Evaluation Boards Reference Design [Analog Devices Wiki]
I found that Audio portion is not necessary for ADV7511 according to the answer here https://ez.analog.com/message/122520#122520
So I removed the Audio IP core and DMA channel from Reference Design and disabled Audio relate code in .c files.
I am using vivado 2015.1.
After download hardware and software program, the screen display a full green. As below:
I find an explanation of HDL IP core Registers here http://wiki.analog.com/resources/fpga/docs/hdl#building_on_vivado
So I print HDL cores register value .
CLKGEN REGs are from ClockGenerator (axi_clkgen) IP core.
HDMITXCORE REGs are from HDMI Transmit (axi_hdmi_tx) IPcore.
VDMA regs are from Xilinx VDMA IP core.
*****CLKGEN REG*****
0x00000040 is :0x00000003
0x0000005C is :0x00000000
0x00000070 is :0x004F8000
0x00000074 is :0x00028000
*****HDMITXCORE REG*****
0x00000040 is :0x00000001
0x00000044 is :0x00000000
0x00000048 is :0x00000001
0x0000004C is :0x00000000
0x00000054 is :0x00017C57
0x00000058 is :0x00000001
0x0000005C is :0x00000001
0x00000060 is :0x00000001
0x00000064 is :0x00000003
0x00000400 is :0x07800898
0x00000404 is :0x00000058
0x00000408 is :0x086C00EC
0x00000440 is :0x04380465
0x00000444 is :0x00000005
0x00000448 is :0x04610029
VDMA - Partial Register Dump (uBaseAddr = 0x43000000):
  PARKPTR          = 0x00010000
  S2MM_DMACR       = 0x00000000
  S2MM_DMASR       = 0x00000000
  S2MM_STRD_FRMDLY = 0x00000000
  S2MM_START_ADDR0 = 0x00000000
  S2MM_START_ADDR1 = 0x00000000
  S2MM_START_ADDR2 = 0x00000000
  S2MM_HSIZE       = 0x00000000
  S2MM_VSIZE       = 0x00000000
  MM2S_DMACR       = 0x00010003
  MM2S_DMASR       = 0x00011000
  MM2S_STRD_FRMDLY = 0x00001E00
  MM2S_START_ADDR0 = 0x02000000
  MM2S_START_ADDR1 = 0x02000000
  MM2S_START_ADDR2 = 0x02000000
  MM2S_HSIZE       = 0x00001E00
  MM2S_VSIZE       = 0x00000438
  S2MM_HSIZE_STATUS= 0x00000000
  S2MM_VSIZE_STATUS= 0x00000000
It seems the VDMA is OK.
Are there something wrong with ClockGenerator (axi_clkgen)  or HDMI Transmit (axi_hdmi_tx) ?
How can I fix the problem?
Thank you very much !
