bf706 secure boot not working with Si REV 1.0
Question asked by alban on Aug 12, 2015
Latest reply on Aug 13, 2015 by alban
Hello
i tried to make to EE366 work on a BF706 target
i managed to make it work with CCES 110 on the EZKIT lite REV1.2 (bf707 rev 0.0B)
i built a simple blinky app, and i was able to boot in standard mode and BLX secure mode using the "EE366 secureboot_openpart" dxe app
i'm working on a project which uses a BF706 rev1.0 date code 1452 (december 2014)
i'm able to boot a blinky app using the "EE366 secureboot_openpart"   in normal mode only !
in secure boot (BLx or BLp) the program get stuck at address 0x040026da
before it proceeds to the Hook with cause = ROM_HOOK_CALL_CONFIG_COMPLETE
i built the ldr file with the -nofillblock option set, and bcode = 1
below is detailled the content of the ADI_ROM_BOOT_CONFIG structure
please note the last field :  errorReturn _Uint32t 0x04001a26  (not documented)
and "secureBootImageType ROM_SB_IMAGE_TYPE ROM_SB_IMAGE_UNKNOWN "
ADI_ROM_BOOT_CONFIG *)(0x11807ccc) ADI_ROM_BOOT_CONFIG* 0x11807ccc
ADI_ROM_BOOT_CONFIG {...}
  pSource void * 0x00000010
  pDestination void * 0x00000000
  dByteCount _Int32t 0x00000000
  dFlags _Int32t 0x00040000
  ulBlockCount _Uint32t 0x00000000
  ulBlockCurrent _Uint32t 0x00000000
  pNextDxe void * 0x00000000
  pControlRegister volatile uint32_t* 0x00000000
  dControlValue _Int32t 0x00000003
  pPeripheralBase volatile uint32_t* 0x20057000
  pAuxControlRegister volatile uint32_t* 0x00000000
  pAuxPeripheralBase volatile uint32_t* 0x00000000
  pSecControlRegister volatile uint32_t* 0x20004960
  pDmaBaseRegister volatile ADI_DMA_TypeDef* 0x20085000
  loadType ROM_DMA_DONE_DETECT_METHOD ROM_DMA_DONE_POLL_IRQDONE
  MdmaCfg ROM_DMA_MDMA_CONFIG {...}
  uwDataWidth unsigned short 0
  uwSrcModifyMult unsigned short 1
  uwDstModifyMult unsigned short 1
  uwUserShort unsigned short 0
  dUserLong _Int32t 0x00000000
  dReserved _Int32t 0x00000000
  pModeData void * 0x11807dac
  dBootCommand _Int32t 0x20211202
  pHeader ADI_ROM_BOOT_HEADER* 0x08001810
  pTempBuffer void * 0x00000000
  pTempBufferPrefetch void * 0x00000000
  dTempByteCount _Int32t 0x00000400
  pTempSource void * 0xffffffff
  dPageByteCount _Int32t 0x00000004
  bootBuffers ADI_ROM_BOOT_INTER_BUFFERS {...}
  bootRegistry ADI_ROM_BOOT_REGISTRY {...}
  pErrorFunction ROM_BOOT_ERROR_FUNC* 0x00000000
  pCallBackFunction ROM_BOOT_CALLBACK_FUNC* 0x0400176c
  pCrcFunction ROM_BOOT_CALLBACK_FUNC* 0x00000000
  pForwardFunction ROM_BOOT_CALLBACK_FUNC* 0x00000000
  bootModes ADI_ROM_BOOT_MODES {...}
  pLogBuffer void * 0x00000000
  pLogCurrent void * 0x00000000
  dLogByteCount _Int32t 0x00000000
  pOtpBootInfo ADI_ROM_OTP_BOOT_INFO* 0x11807f24
  keyType ADI_ROM_BOOT_KEY_TYPE ADI_ROM_CUSTOM_SECURITY
  bootType ADI_ROM_BOOT_TYPE ADI_ROM_SECURE_BOOT
  reserved0 void * 0x08001820
  publicKey ADI_SBIF_ECDSA_PublicKey_t {...}
  cryptoDescriptors CRYPTO_DESCRIPTORS {...}
  reserved1 void * 0x08001aec
  secureBytesRemaining _Int32t 0x00000000
  aesKey uint32_t[] {...}
  aesWrapKey uint32_t[] {...}
  IV uint32_t[] {...}
  pHash uint8_t* 0x08001acc
i tested my proto board with and old BF706 rev0.0B (1410)
i was able to secure boot in blx mode, so i can conclude that my board and the flash i use are not part of the problem
below are the contents of the boot info struct after secure booting
as you can see the BLX image type is properly recognized,
and the dflags indicate that the image was fully loaded
(ADI_ROM_BOOT_CONFIG *)(0x11807ccc) ADI_ROM_BOOT_CONFIG* 0x11807ccc
  pSource void * 0x40002fc8
  pDestination void * 0x11a00000
  dFlags _Int32t 0x000c8001
  ulBlockCurrent _Uint32t 0x00000018
  pNextDxe void * 0x40002fc8
  dControlValue _Int32t 0x80000043
  pDmaBaseRegister volatile ADI_DMA_TypeDef* 0x2008d000
  loadType ROM_DMA_DONE_DETECT_METHOD ROM_DMA_DONE_NON_BLOCKING
  dBootCommand _Int32t 0x00000007
  pTempSource void * 0x40002cb4
  pCallBackFunction ROM_BOOT_CALLBACK_FUNC* 0x0400161c
  secureBootImageType ROM_SB_IMAGE_TYPE ROM_SB_IMAGE_BLX
  reserved1 void * 0x08001ae4
  IV uint32_t[] {...}
  pHash uint8_t* 0x08001ac4
  errorReturn _Uint32t 0x00000000
the question are :
does the EE366 have been tested with the BF706 rev 1.0 ?
(did AD release the EE366 app note BEFORE the bf706 si REV1.0 ? )
could you give me some clue on how get the thing work ?
thank you for your support
i'm sorry but this is very urgent
Alban
