Is there a solution for the adf5355 driver Division by zero in kernel?
Question asked by EdwardK on Aug 11, 2015
Latest reply on Aug 13, 2015 by EdwardK
To reproduce on linux-adi branch xcomm_zynq
1) git clone https://github.com/analogdevicesinc/linux.git
2) git checkout fa4b516ebb4e6be181df0e4d60506ab849249d44 drivers/spi/spi-xilinx.c if you are using a Zynq
3) dtsi entries
/include/ "skeleton.dtsi"
  fixed_ref_clk: clock@0 { /* Fixed adf5355_regulator reference clock */
  compatible = "fixed-clock";
  #clock-cells = <0>;
  clock-frequency = <100000000>;
  clock-accuracy = <5>; /* ppb */
  adf5355_regulator: fixedregulator@1 {
  compatible = "regulator-fixed";
  regulator-name = "adf5355-fixed-supply";
  regulator-min-microvolt = <3300000>;
  regulator-max-microvolt = <3300000>;
  regulator-boot-on;
  regulator-always-on;
&axi_quad_spi_1 {
  #address-cells = <1>;
  #size-cells = <0>;
  wb_lo_adf5355: wb-lo-adf5355-tx@1 {
  compatible = "adf5355";
  reg = <1>;
  spi-max-frequency = <20000000>;
  clocks = <&fixed_ref_clk>;
  clock-names = "clkin";
  clock-output-names = "adf5355_out";
  vcc-supply = <&adf5355_regulator>;
  regulator-name = "vcc";
  adi,reference-div2-enable;
  adi,charge-pump-current = <900>;
  adi,muxout-select = <6>;
  adi,mute-till-lock-enable;
  adi,output-a-power = <3>;
  adi,output-b-power = <0>;
  adi,charge-pump-negative-bleed-enable;
  adi,reference-differential-input-enable;
  adi,muxout-level-3v3-enable;
  adi,power-up-frequency = <464000000>;
4) Error reported
Division by zero in kernel.
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.0.0-xilinx-adi-gdf9be52-dirty #1
Hardware name: Xilinx Zynq Platform
[<c00167bc>] (unwind_backtrace) from [<c00127c0>] (show_stack+0x10/0x14)
[<c00127c0>] (show_stack) from [<c0475ba4>] (dump_stack+0x98/0xd8)
[<c0475ba4>] (dump_stack) from [<c024a75c>] (Ldiv0_64+0x8/0x18)
[<c024a75c>] (Ldiv0_64) from [<c03ade40>] (adf5355_pll_fract_n_get_rate+0x34/0x88)
[<c03ade40>] (adf5355_pll_fract_n_get_rate) from [<c03adea8>] (adf5355_clk_recalc_rate+0x14/0x34)
[<c03adea8>] (adf5355_clk_recalc_rate) from [<c039d830>] (clk_register+0x380/0x738)
[<c039d830>] (clk_register) from [<c03aed08>] (adf5355_probe+0x4d4/0x5d4)
[<c03aed08>] (adf5355_probe) from [<c0329d40>] (spi_drv_probe+0x50/0x74)
[<c0329d40>] (spi_drv_probe) from [<c02da2c8>] (driver_probe_device+0x13c/0x398)
[<c02da2c8>] (driver_probe_device) from [<c02da5f4>] (__driver_attach+0x8c/0x90)
[<c02da5f4>] (__driver_attach) from [<c02d85dc>] (bus_for_each_dev+0x6c/0xa0)
[<c02d85dc>] (bus_for_each_dev) from [<c02d9974>] (bus_add_driver+0x15c/0x218)
[<c02d9974>] (bus_add_driver) from [<c02da9b0>] (driver_register+0x78/0xf8)
[<c02da9b0>] (driver_register) from [<c000891c>] (do_one_initcall+0xb8/0x1f0)
[<c000891c>] (do_one_initcall) from [<c0623d84>] (kernel_init_freeable+0x148/0x1e8)
[<c0623d84>] (kernel_init_freeable) from [<c04724fc>] (kernel_init+0x8/0xe8)
[<c04724fc>] (kernel_init) from [<c000f380>] (ret_from_fork+0x14/0x34)
Any help is appreciated.
mhennerich
I am looking at the clock stuff to see if that changed
