64 bit fixed point multiplication of two different input Q-formats
Question asked by Balakumar08 on Aug 11, 2015
Latest reply on Aug 21, 2015 by Harshit.Gaharwar
Hi to All,
     I am trying to do multiply two 64bit values using fixed point integer multiplication.  In the following method
static Fix64 operator *(Fix64 x, Fix64 y)
var xl = x.m_rawValue; // underlying long of x
var yl = y.m_rawValue; // underlying long of y
var xlow = xl & 0x00000000FFFFFFFF; // take the 32 lowest bits of x
var xhigh = xl >> 32; // take the 32 highest bits of x
var ylow = yl & 0x00000000FFFFFFFF; // take the 32 lowest bits of y
var yhigh = yl >> 32; // take the 32 highest bits of y
// perform multiplications
var lowlow = xlow * ylow;
var lowhigh = xlow * yhigh;
var highlow = xhigh * ylow;
var highhigh = xhigh * yhigh;
// take the highest bits of lowlow and the lowest of highhigh
var loResult = lowlow >> 32;
var midResult1 = lowhigh;
var midResult2 = highlow;
var hiResult = highhigh << 32;
// add everything together and build result
var finalResult = loResult + midResult1 + midResult2 + hiResult;
and the result be also in 64bit format. this works for same  format multiplication that is Q(4.60)*Q(4.60)=Q(4.60).
we need to consider sign bit also in the multiplication.
for different format Q(2.62)*Q(7.57)=Q(8.56) is not coming on the result.MaheshNjeyanthi.jegadeesan
Thanks advance,
Balakumar.M
