Mixed C/Assembly by using the alternate registers as context-switch?
Question asked by heikon on Jul 31, 2015
Latest reply on Aug 21, 2015 by Harshit.Gaharwar
Hi everyone,
i have a question about calling a assembly function from a C function. The ADSP21061 is in use.
I want to use the alternate register instead of saving all registers on to the stack. So the programm sequence would be:
C-File:                               ASM-File:
Call_ASM-Function();          _Call_ASM-Function:
                                             leaf_entry;
                                             push sts;
                                             bit set mode1 SRD1L|SRD1H|SRRFL|SRRFH;
                                             nop;
                                                  /* Beginnung of the Code*/
                                                  /* End of the Code*/
                                             bit clr mode1 SRD1L|SRD1H|SRRFL|SRRFH;
                                             nop;
                                             pop sts;
                                             leaf_exit;
                                             _Call_ASM-Function.end:
....and now we´re back in C
In the ASM-Function (Call_ASM-Function()) two interrupts will be enabled, one of them asume to save the ASTAT-register.
So the interrupt occurs only when i´m in "assembly-mode", so they should work also on the alternate regsiter (this should be not problem because the register used in ISR are NOT used in ASM-Function).
In the Simulation everything works fine, but not on the hardware. I do not know if the source of error is the interrupt-handling, but i want to make sure that this is not the problem.
The error occurs NOT frequently, so sometimes it works fine sometimes not. Remember that i have no debug-possibility on the hardware.
Kind regards,
