ADV7619 and HDCP
Question asked by boweiguo on Jul 29, 2015
Latest reply on Jul 31, 2015 by DaveD
When use the first source,ADV7619 work well. The regiter(HDMI-0X05) indicate the input stream processed by HDMI core is not HDCP encrypted.
When use the second source,it display nothing. The regiter(HDMI-0X05) indicate the input stream processed by HDMI core is HDCP encrypted.
which register i configed wrong?
err += ADV_ProgW(sel,ADV_IO_SLA,0xFF,0x80); //I2C RESET
  err += ADV_ProgW(sel,ADV_IO_SLA,0xF4,ADV_CEC_SLA); //set the addr for the CEC-------80
  err += ADV_ProgW(sel,ADV_IO_SLA,0xF5,ADV_CEC_SLA); //set the addr for the INFOFRAME-7C
  err += ADV_ProgW(sel,ADV_IO_SLA,0xF8,ADV_DPLL_SLA); //set the addr for the DPLL-----4C
  err += ADV_ProgW(sel,ADV_IO_SLA,0xF9,ADV_KSV_SLA); //set the addr for the KSV-------64
  err += ADV_ProgW(sel,ADV_IO_SLA,0xFA,ADV_EDID_SLA); //set the addr for the EDID-----6C
  err += ADV_ProgW(sel,ADV_IO_SLA,0xFB,ADV_HDMI_SLA); //set the addr for the HDMI-----68
  err += ADV_ProgW(sel,ADV_IO_SLA,0xFD,ADV_CP_SLA); //set the addr for the CP---------44
  err += ADV_ProgW(sel,ADV_IO_SLA,0x74,0x00); //Disable the Internal EDID for all ports
    for(i=0;i<256;i++)
      err += ADV_ProgW(sel,ADV_EDID_SLA,i,ADV_Default_EDID[i]);//how to describe the address?
  err += ADV_ProgW(sel,ADV_IO_SLA,0x71,0x00); //Set the Most Significant Bit of the SPA location to 0
  err += ADV_ProgW(sel,ADV_KSV_SLA,0x52,0x20); //Set the SPA for port B
  err += ADV_ProgW(sel,ADV_KSV_SLA,0x53,0x00); //Set the SPA for port B.
  err += ADV_ProgW(sel,ADV_KSV_SLA,0x70,0x9E); //Set the Least Significant Byte of the SPA location
  err += ADV_ProgW(sel,ADV_KSV_SLA,0x74,0x01); //Enable the Internal EDID for ports A
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0xC0,0x03); //ADI Recommended Write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x00,0x08); //set port B as a background
  err += ADV_ProgW(sel,ADV_IO_SLA,0x01,0x06); //Prim_Mode =110b HDMI-GR
  err += ADV_ProgW(sel,ADV_IO_SLA,0x02,0xF2); //Auto CSC, RGB out, Set op_656 bit
  err += ADV_ProgW(sel,ADV_IO_SLA,0x03,0x54); //2x24 bit SDR 444 interleaved mode 0
  err += ADV_ProgW(sel,ADV_IO_SLA,0x04,0x60); //27M crystal
  err += ADV_ProgW(sel,ADV_IO_SLA,0x05,0x28); //AV Codes Off
  err += ADV_ProgW(sel,ADV_IO_SLA,0x06,0xA0); //No inversion on VS,HS LLC pins,Negative polarity of HS VS
  err += ADV_ProgW(sel,ADV_IO_SLA,0x0C,0x42); //Power up part
  err += ADV_ProgW(sel,ADV_IO_SLA,0x14,0x6A); //Driver length for data/clk/sync
  err += ADV_ProgW(sel,ADV_IO_SLA,0x15,0xB0); //Disable Tristate of Pins-----A0/80
  err += ADV_ProgW(sel,ADV_IO_SLA,0x19,0x93); //LLC DLL phase----------------
  err += ADV_ProgW(sel,ADV_IO_SLA,0x33,0x40); //LLC DLL MUX enable
// err += ADV_ProgW(sel,ADV_IO_SLA,0xBF,0x00); //2x24 bit SDR 444 interleaved mode 0
  err += ADV_ProgW(sel,ADV_IO_SLA,0xDD,0xA0); //LLC Half frequency
  err += ADV_ProgW(sel,ADV_DPLL_SLA,0xB5,0x01); //Setting MCLK to 256Fs
  err += ADV_ProgW(sel,ADV_DPLL_SLA,0xC3,0x80); //ADI recommended writes for 2x24 bit (HiFreq)
  err += ADV_ProgW(sel,ADV_DPLL_SLA,0xCF,0x03); //ADI recommended writes for 2x24 bit(HiFreq)
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0xC0,0x03); //ADI Required write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x00,0x08); //Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x02,0x03); //ALL BG Ports enabled
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x03,0x98); //ADI Required Write-------AUDIO
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x10,0xA5); //ADI Required Write-------25-NONE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x45,0x04); //ADI Required Write--------NONE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x97,0xC0); //ADI Required Write--------NONE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x3D,0x10); //ADI Required Write--------NONE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x3E,0x69); //ADI reccommended writes---NONE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x3F,0x46); //ADI reccommended writes---NONE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x4E,0xFE); //ADI reccommended writes---NONE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x4F,0x08); //ADI reccommended writes---NONE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x50,0x00); //ADI Recommended Write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x57,0xA3); //ADI Recommended Write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x58,0x07); //ADI Recommended Write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x6C,0x62); //HPA OUTPUT AFTER +5V DETECTION 0~1.5S,NOW IS 0.4S
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x83,0xFC); //Enable clock terminators for port A & B
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x84,0x03); //FP MODE
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x85,0x10); //ADI Recommended Write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x86,0x9B); //ADI Recommended Write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x89,0x03); //HF Gain
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x9B,0x03); //ADI Recommended Write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x93,0x03); //ADI Recommended Write
  err += ADV_ProgW(sel,ADV_HDMI_SLA,0x5A,0x80); //ADI Recommended Write
