Clocking the DMA data output to the AD9122
Question asked by tjdub21 on Jul 23, 2015
Latest reply on Jul 30, 2015 by AdrianC
I am using the KC705 for the FMCOMMS1 reference design. I would like to modify the block diagram to match my needs which are:
1) I need to write data to memory
2) I need to pull that data from memory with the DMA controller that feeds to the AD9122 DAC.
3) I need to clock my output data from the DAC at a given clock (SCLK).
I have used the reference design to write to the memory using the dac_dma_setup() function in SDK. I have attempted to make modifications to the block diagram to use my SCLK to clock the data that is read from memory and fed to the DAC but I have been unsuccessful.
In summary, I would like to pull data from the DMA data at the rate of SCLK (my signal) and output at that rate from the DAC. Is there a way for me to do this by modifying the block diagram in Vivado? I have modified the original FMCOMMS1 block diagram and it is attached.
In the block diagram I have fed my SCLK signal to the fifo_rd_clk on the AD9122_dma IP block and to the output dac_clk signal. I was hoping that this would work but it did not.
Thanks and if you have any questions then let me know!
