AD9361 fmcomms2 kc705 project
Question asked by vongy on Jul 23, 2015
Latest reply on Jul 23, 2015 by CsomI
When I rebuild hdl-hdl_2015_r1, I got the following error:
I work with this version 2014.4.1 of VIVADO.
### set sys_rstgen [create_bd_cell -type ip -vlnv xilinx.com:ip:proc_sys_reset:5.0 sys_rstgen]
### set axi_ddr_cntrl [create_bd_cell -type ip -vlnv xilinx.com:ip:mig_7series:2.3 axi_ddr_cntrl]
### set axi_ddr_cntrl_dir [get_property IP_DIR [get_ips [get_property CONFIG.Component_Name $axi_ddr_cntrl]]]
### file copy -force $ad_hdl_dir/projects/common/kc705/kc705_system_mig.prj "$axi_ddr_cntrl_dir/"
### set_property -dict [list CONFIG.XML_INPUT_FILE {kc705_system_mig.prj}] $axi_ddr_cntrl
child killed: unknown signal
ERROR: [IP_Flow 19-3475] Tcl error in ::ipgui_system_axi_ddr_cntrl_0::updateAllModelParams procedure for BD Cell '/axi_ddr_cntrl'. child killed: unknown signal
INFO: [IP_Flow 19-3438] Customization errors found on '/axi_ddr_cntrl'. Restoring to previous valid configuration.
ERROR: [BD 41-245] set_property error - Customization errors found on '/axi_ddr_cntrl'. Restoring to previous valid configuration.
INFO: [Common 17-17] undo 'set_property'
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
Thanks.
