adau1961 alsa problem
Question asked by wlecust06 on Jul 23, 2015
Latest reply on Aug 3, 2015 by larsc
Dear Larsc:
I use your adau17x1.c and adau1761.c which is released in 2011, and merge to linux 3.2.0 in am335x.
I meet the problem ,I use the following command ,it show that Left DAC and pll  ,sysclk are all off.
cat  /sys/devices/platform/soc-audio.0/ADAU1X61/dapm_widget
Headphone VGND: On
Right ADC: Off
Left ADC: Off
Right DAC: Off
Left DAC: Off
Right Playback Enable: On
Left Playback Enable: On
MICBIAS: Off
AIFCLK: Off
PLL: Off
SYSCLK: Off
Headphone: On
Right LR Playback Mixer: On
Left LR Playback Mixer: On
Right Playback Mixer: On
Left Playback Mixer: On
Right Input Mixer: On
Left Input Mixer: On
PM State: On
I found that there is no amixer option to change it .
The following is the output of amixer , I heard the song  when I transplant your code to my platform in 2 years ago.
I use a new board,it do not work now,I have checked that the MCLK and  BCLK  LRCLK of iis are fine.
But when I use  aplay xxx.wav ,I can not heard the song.
I remerber  that  SYSCLK ,Right DAC,Left DAC,are on when it work fine in the past.
Can you tell me how to change the
root@am335x-evm:~# amixer contents
numid=21,iface=MIXER,name='Headphone Bias'
  ; type=ENUMERATED,access=rw------,values=1,items=4
  ; Item #0 'Normal operation'
  ; Item #1 'Extreme power saving'
  ; Item #2 'Enhanced performance'
  ; Item #3 'Power saving'
  : values=0
numid=14,iface=MIXER,name='Headphone Playback Switch'
  ; type=BOOLEAN,access=rw------,values=2
  : values=on,on
numid=13,iface=MIXER,name='Headphone Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=63,step=0
  : values=48,48
  | dBscale-min=-57.00dB,step=1.00dB,mute=0
numid=16,iface=MIXER,name='Lineout Playback Switch'
  : values=on,on
numid=15,iface=MIXER,name='Lineout Playback Volume'
  : values=62,62
numid=6,iface=MIXER,name='Mic Bias Mode'
  ; type=ENUMERATED,access=rw------,values=1,items=2
  ; Item #1 'High performance'
  : values=0
numid=12,iface=MIXER,name='Aux Capture Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=7,step=0
  : values=0,0
  | dBscale-min=-15.00dB,step=3.00dB,mute=1
numid=17,iface=MIXER,name='ADC Bias'
  : values=0
numid=3,iface=MIXER,name='ADC High Pass Filter Switch'
  ; type=BOOLEAN,access=rw------,values=1
  : values=off
numid=19,iface=MIXER,name='Capture Bias'
  ; type=ENUMERATED,access=rw------,values=1,items=3
  ; Item #1 'Enhanced performance'
  ; Item #2 'Power saving'
  : values=0
numid=5,iface=MIXER,name='Capture Boost'
  ; Item #1 'Boost Level 1'
  ; Item #2 'Boost Level 2'
  ; Item #3 'Boost Level 3'
  : values=0
numid=20,iface=MIXER,name='Playback Bias'
  : values=0
numid=4,iface=MIXER,name='Playback De-emphasis Switch'
  : values=off
numid=18,iface=MIXER,name='DAC Bias'
  : values=0
numid=7,iface=MIXER,name='DAC Mono Stereo'
  ; Item #0 'Stereo'
  ; Item #1 'Mono Left Channel (L+R)'
  ; Item #2 'Mono Right Channel (L+R)'
  ; Item #3 'Mono (L+R)'
  : values=0
numid=1,iface=MIXER,name='Digital Capture Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=255,step=0
  : values=255,255
  | dBminmax-min=-95.63dB,max=0.00dB
numid=2,iface=MIXER,name='Digital Playback Volume'
  : values=255,255
numid=8,iface=MIXER,name='Input 1 Capture Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=0,max=7,step=0
  : values=0
numid=9,iface=MIXER,name='Input 2 Capture Volume'
  : values=0
numid=10,iface=MIXER,name='Input 3 Capture Volume'
  : values=0
numid=11,iface=MIXER,name='Input 4 Capture Volume'
  : values=0
numid=24,iface=MIXER,name='Left LR Playback Mixer Left Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=0,max=2,step=0
  : values=2
  | dBscale-min=-6.00dB,step=6.00dB,mute=1
numid=25,iface=MIXER,name='Left LR Playback Mixer Right Volume'
  : values=1
numid=33,iface=MIXER,name='Left Playback Mixer Aux Bypass Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=0,max=8,step=0
  : values=8
  | dBscale-min=-18.00dB,step=3.00dB,mute=1
numid=35,iface=MIXER,name='Left Playback Mixer Left Bypass Volume'
  : values=3
numid=31,iface=MIXER,name='Left Playback Mixer Left DAC Switch'
  : values=on
numid=34,iface=MIXER,name='Left Playback Mixer Right Bypass Volume'
  : values=2
numid=32,iface=MIXER,name='Left Playback Mixer Right DAC Switch'
  : values=on
numid=22,iface=MIXER,name='Right LR Playback Mixer Left Volume'
  : values=1
numid=23,iface=MIXER,name='Right LR Playback Mixer Right Volume'
  : values=2
numid=28,iface=MIXER,name='Right Playback Mixer Aux Bypass Volume'
  : values=4
numid=30,iface=MIXER,name='Right Playback Mixer Left Bypass Volume'
  : values=2
numid=26,iface=MIXER,name='Right Playback Mixer Left DAC Switch'
  : values=on
numid=29,iface=MIXER,name='Right Playback Mixer Right Bypass Volume'
  : values=2
numid=27,iface=MIXER,name='Right Playback Mixer Right DAC Switch'
  : values=on
