FMCOMMS3 ADC DMA logging data rate
Question asked by notme on Jul 22, 2015
Latest reply on Jul 30, 2015 by mhennerich
I'm using the zedboard with FMCOMMS3 with hdl_2014_r2 and NO_OS (2014_r2).
I am trying to log data from the FMCOMMS3 over ethernet using UDP.
I am queuing the DMA to constantly collect ADC data, and I use polling to transmit over UDP once a packet of data is collected.  I'm receiving exactly 4X less data than the fmcomms3 board should be producing.
Do you have any recommendations on things I can try to debug the problem?  I borrowed heavily from thread 40344
uint32_t adc_capture_submit(uint32_t size, uint32_t start_address)
          uint32_t reg_val;
          uint32_t transfer_id;
          uint32_t length;
          adc_dma_write(AXI_DMAC_REG_CTRL, AXI_DMAC_CTRL_ENABLE);
          adc_dma_read(AXI_DMAC_REG_TRANSFER_ID, &transfer_id);
          adc_dma_read(AXI_DMAC_REG_IRQ_PENDING, &reg_val);
          adc_dma_write(AXI_DMAC_REG_IRQ_PENDING, reg_val);
          adc_dma_write(AXI_DMAC_REG_DEST_ADDRESS, start_address);
          adc_dma_write(AXI_DMAC_REG_DEST_STRIDE, 0x0);
          adc_dma_write(AXI_DMAC_REG_X_LENGTH, size - 1);
          adc_dma_write(AXI_DMAC_REG_Y_LENGTH, 0x0);
          adc_dma_write(AXI_DMAC_REG_START_TRANSFER, 0x1);
          /* Wait until the new transfer is queued. */
          do {
                    adc_dma_read(AXI_DMAC_REG_START_TRANSFER, &reg_val);
          while(reg_val == 1);
          return transfer_id;
          return transfer_id;
void adc_capture_wait(uint32_t transfer_id)
          uint32_t reg_val;
          /* Wait until the transfer with the ID transfer_id is completed. */
          do {
                    adc_dma_read(AXI_DMAC_REG_TRANSFER_DONE, &reg_val);
          while((reg_val & (1 << transfer_id)) != (1 << transfer_id));
And in main,
const unsigned int BUFFER_ADDR[2] = {ADC_DDR_BASEADDR+HEADER_SIZE, ADC_DDR_BASEADDR + ADC_TRANSFER_SIZE + 2*HEADER_SIZE};
buffer_transfer_id[0] = adc_capture_submit(ADC_TRANSFER_SIZE, BUFFER_ADDR[0]);
buffer_transfer_id[1] = adc_capture_submit(ADC_TRANSFER_SIZE, BUFFER_ADDR[1]);
for(ever) {
    for (i = 0; i < 2; i++) {
        adc_capture_wait(buffer_transfer_id[i]);
        Xil_DCacheInvalidateRange(BUFFER_ADDR[i], ADC_TRANSFER_SIZE);
        send_data_to(BUFFER_ADDR[i]-HEADER_SIZE, ADC_TRANSFER_SIZE + HEADER_SIZE, &ipaddr, port);
        buffer_transfer_id[i] = adc_capture_submit(ADC_TRANSFER_SIZE, BUFFER_ADDR[i]);
void send_data_to (unsigned int address, unsigned int size, struct ip_addr *addr, u16_t port){
    struct pbuf *p = pbuf_alloc(PBUF_TRANSPORT, size, PBUF_REF);
    p->payload = (void*) address; //data in payload is volatile, could cause problems
    ((uint32_t*)p->payload)[0] = 60 + (1 << 8);
    ((uint32_t*)(p->payload))[1] = packet_count++;
    udp_sendto(pcb, p, addr, port); //destination port
    xemacif_input(&server_netif);
    pbuf_free(p);
I set the sampling rate to 15Mhz.  ad9361_set_rx_sampling_freq(ad9361_phy, 15360000);
I am only using one channel, I'm checking for lost packets, and I'm getting around 112,000 packets of 8184 bytes in one minute, so 15Mbytes per second.  I'm expecting I and Q data of 16 bits a piece, at 15Mhz., so I'm expecting 4 times as much data.
Doubling the sampling frequency doubles the data I log, so I don't think there is a bottleneck.
