Problems with GPIO and PWM 180-Pin Probing
Question asked by yvg on Jul 21, 2015
Latest reply on Aug 12, 2015 by yvg
Hi there!
I am using the CM408f with the 180-Pin Probing Test connected to J6.
Is the following correlation of the pins of the processor and the lead of the 180-Pin Probing correct?
PA_13  ---- Lead number  1
PA_07  ---- Lead number  14
PE_05  ---- LED3 ---Lead number 91
PE_06  ---- LED2 ---Lead number 90
PE_07  ---- LED1 ---Lead number 89
Is the software configuration correct for the GPIO output pins?
To check it, I modified the Button_LED_GPIO.c  example code.
    First. I introduced Timer ISR.
    Second. Inside the timer ISR the LED3 toggles every 1000 interruptions.
The results are:
    1. Once the code is downloaded, the LED3 blinks. Therefore, the ISR is working well.
      I checked the LED3 (directly in the LED) with the scope; then, I could see the square signal. But no signal was found, when I checked the PIN 91 in the pin probing .
    2. LED1 and LED2. I switched SW4 and SW5, LED1 and LED2 switched on/off respectively (toggle).
    I checked directly in the LEDs, and the signal was 1 and 0 logic (3 volts and 0 volts), but I tried to see the same signal in their corresponding pins with the scope (pins 89 and 90 of the pin probing board) and no signal was found .
I also changed the pin probing from J6 to J4 and It doesn’t work.
You will find the c-code below.
I would be very grateful if someone can help.
// Piece of code introduced in Button_LED_GPIO.c
// Timer3 ISR setup
void aSetupSchedulerIrq(void){
    *pREG_TIMER0_TMR3_CFG = 0x883C;
    *pREG_TIMER0_TMR3_PER = (uint32_t)8000;
    *pREG_TIMER0_TMR3_WID = (uint32_t)4000;
    adi_int_InstallHandler((IRQn_Type)INTR_TIMER0_TMR3, TIMER0_TMR3_ISR, 0, true);
    NVIC_SetPriority((IRQn_Type)INTR_TIMER0_TMR3, 1);
    NVIC_EnableIRQ((IRQn_Type)INTR_TIMER0_TMR3);
    *pREG_TIMER0_DATA_IMSK &= 0xF5;
    *pREG_TIMER0_RUN_SET = 0xA;
// Timer3 ISR
void TIMER0_TMR3_ISR(uint32_t iid, void* handlerArg){
    *pREG_TIMER0_DATA_ILAT = BITM_TIMER_DATA_ILAT_TMR03;
    auxiliar_count++;
    if (auxiliar_count >=1000){
          auxiliar_count = 0;
          adi_gpio_Toggle(ADI_GPIO_PORT_A, ADI_GPIO_PIN_13);
          adi_gpio_Toggle(ADI_GPIO_PORT_E, ADI_GPIO_PIN_5);  // LED3
// End of the code ***********************************
// The GPIOs are configured in output mode, see code below.
/* set GPIO output LED 1 */
  result = adi_gpio_SetDirection(
                                ADI_GPIO_PORT_E,
                                ADI_GPIO_PIN_7,
                                ADI_GPIO_DIRECTION_OUTPUT);
  CheckResult(result, "adi_gpio_SetDirection");
/* set GPIO output PA_07 -- PIN 14 */
                              ADI_GPIO_PORT_E,
                              ADI_GPIO_PIN_5,
  /* set GPIO output PA_13 -- PIN 1 */
                              ADI_GPIO_PORT_A,
                              ADI_GPIO_PIN_13,
  /* set GPIO output LED 2 */
                                ADI_GPIO_PORT_E,
                                ADI_GPIO_PIN_6,
