SPORT TX DMA IRQ - BF561
Question asked by Laz on Apr 19, 2011
Latest reply on Apr 25, 2011 by Laz
I am trying to get an interrupt at the end of a SPORT TX sequence.  I have configured the SPORT and DMA below.  I can see on the scope that the data string is being sent, and the DMA Complete bit is set, but I don't get the IRQ (the ISR is never called).
I've looked at the Audio Codec Talk-through example, and my code looks similar.  I'm probably missing something simple.
TIA;
Dan
// init the ISR
Void initSportISR()
            register_handler_ex(ik_ivg9, slaveTxRxIsr, EX_INT_ENABLE);               // assign ISR to interrupt vector
            *pSICA_IAR2 = Peripheral_IVG(23,9);                   // assign interrupt channel 23 DMA SPORT0 RX to IVG9
            *pSICA_IAR3 = Peripheral_IVG(24,9);                   // assign interrupt channel 24 DMA SPORT0 TX to IVG9
            *pSICA_IMASK0 |= SIC_MASK(9);           // un-mask the IRQ
            ssync();
            *pILAT |= EVT_IVG9;                                  // clear pending IVG9 interrupts
            ssync();
void transmitSlave( BYTE  *buf, int  bufSize)
// config the DMA
            *pSPORT0_RCR1 = 0; // turn off RECV
            *pDMA2_1_IRQ_STATUS = 0x0f; // clear all flags
            *pDMA2_1_PERIPHERAL_MAP               = 0x1000; // set to SPORT0_TX
            // set up DMA transfer
            *pDMA2_1_START_ADDR = buf; // data buffer
            *pDMA2_1_X_COUNT        = bufSize;        // this is the number of bytes to send
            *pDMA2_1_X_MODIFY = 1;          // 8-bit data
            // Enable DMA, read from mem, 8-bit, En IRQ, clear FIFO,
            *pDMA2_1_CONFIG = DMAEN | WDSIZE_8 | RESTART | DI_EN; // no Flow = Stop
// config the SPORT
            // configure to transmit on the Primary channel
            *pSPORT0_TCR2 = 7; // 8 data - 1
            // Enable, Internal Clock and Frame, Late Frame required, Frame goes LO
            *pSPORT0_TCR1 = TSPEN | ITCLK | ITFS | TFSR | LTFS | LATFS | TCKFE; // add drive on Falling edge (read on rising)
