AD9361_sim.slx error in Simulink
Question asked by PennyL on Jul 10, 2015
Latest reply on Apr 12, 2018 by travisfcollins
Hi. I am trying to get the FMCOMMS-3 up & running with the Linux distribution and libiio on the ZedBoard Zynq-7000. I am using Matlab R2015a with Simulink. When I open the Simulink model it shows the correct device name and IP address I input into the class definition file (iio_sys_obj.m) but I consistently get the "Index exceeds matrix dimensions" error with:
An error occurred while running the simulation and the simulation was terminated
For output port 1 of 'ad9361_sim/MATLAB System', the 'stepImpl' method of the System object 'iio_sys_obj' returned a value whose size [0x0], does not match the value returned by the 'getOutputSizeImpl' method. Either change the size of the value returned by 'stepImpl', or change the size returned by 'getOutputSizeImpl'.
Component: Simulink | Category: Block error
The function block shows the right setup, IP address & device name as set up by iio_sys_obj.m. It shows the No. of input/output channels at 4 even though they were left blank in the same file.
Where in the iio_sys_obj file do I change the size of the value returned by 'stepImpl', or change the size returned by 'getOutputSizeImpl'? Or is the root cause underlying this error somewhere else in the setup?
Thanks!
