Blimp OSD Tool - reproducing the sample OSD project
Question asked by ChrisInSeoul on Jul 9, 2015
Latest reply on Jul 24, 2015 by ChrisInSeoul
This question is a follow-up to an earlier question:
BLIMP OSD Project Files for EVAL-ADV8005-SMZ
The OSD Demo delivered with the EVAL ADV8005 board, represented by
  • bin file OSD_1.90RC1_20140925.
  • sample application source code 1.90.2 rel. 20150209,
    • 800X_BF_SW/app/8002_AVR/osd/adi_demo2/blimp_*.c, .h files
    • 800X_BF_SW/osd_bmp/es2/include/*.h
    • 800X_BF_SW/osd_bmp/es2/source.c
When I try to build the same project using this file, which is supposed to generate the same OSD demo project as ships with the eval board:
C:\Program Files\Analog Devices\Blimp\SampleProject\ADV800x\AVR_OSD_DEMO\ProjectFiles\
(copied into my own project directory tree)
Building this project under version 3.8 of the Blimp Tool, results in these outputs:
  • blimp/AVR_OSD_DEMO/ProjectFiles/Release/ddr2_dump.bin
  • blimp/AVR_OSD_DEMO/ProjectFiles/Release/blimp_*.c, *.h files
  • blimp/AVR_OSD_DEMO/ProjectFiles/Release/firmware/include/*.h
  • blimp/AVR_OSD_DEMO/ProjectFiles/Release/firmware/source/*.c
Question 1:  These sets of files are quite a bit different.  They may indeed function the same, but the source code files do not match, not one single file matches.  Furthermore, there are two files extra, osd_bmp/es2/source/vsp_osdeg_freetype.c and osd_bmp/es2/include/vsp_osdeg_freetype.h not in the original firmware distribution.  Shouldn't these files match?
Question 2:  After copying these sets of files into the project, I'm not able to build the resulting project.  The build project task dies after a bunch of errors in asp_vsp.c (error messages pasted below).  I could track each of these down and manually fix them. But this suggests I've done something wrong, either building the Blimp OSD project, and/or copying the files over into the Blackfin code.  Any idea what I've done wrong?
-Chris
VisualDSP++ Build Error Output:
.\800X_BF_SW\APP\8002_AVR\VSP\app_vsp.c
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 35: cc0301: {D} warning:
          typedef name has already been declared (with same type)
      typedef          char  CHAR;
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 36: cc0301: {D} warning:
      typedef unsigned char  UCHAR;
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 38: cc0301: {D} warning:
      typedef signed char    INT8;
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 40: cc0301: {D} warning:
      typedef unsigned char  UINT8;
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 41: cc0301: {D} warning:
      typedef short          INT16;
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 42: cc0301: {D} warning:
      typedef unsigned short UINT16;
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 43: cc0256:  error:
          invalid redeclaration of type name "INT32" (declared at line 21 of
          ".\800X_BF_SW\PLATFORM\BF524\atv_types.h")
      typedef int            INT32;
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 44: cc0256:  error:
          invalid redeclaration of type name "UINT32" (declared at line 19 of
      typedef unsigned int   UINT32;
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 49: cc0101:  error:
          "ATVERR_OK" has already been declared in the current scope
          ATVERR_OK    = 0,
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 50: cc0101:  error:
          "ATVERR_FALSE" has already been declared in the current scope
          ATVERR_FALSE = 0,
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 51: cc0101:  error:
          "ATVERR_TRUE" has already been declared in the current scope
          ATVERR_TRUE  = 1,
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 52: cc0101:  error:
          "ATVERR_INV_PARM" has already been declared in the current scope
          ATVERR_INV_PARM,
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 53: cc0101:  error:
          "ATVERR_NOT_AVAILABLE" has already been declared in the current scope
          ATVERR_NOT_AVAILABLE,
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 54: cc0101:  error:
          "ATVERR_FAILED" has already been declared in the current scope
          ATVERR_FAILED
".\800X_BF_SW\OSD_BMP\ES2\include\vsp_osd_stdtypes.h", line 55: cc0256:  error:
          invalid redeclaration of type name "ATV_ERR" (declared at line 362
          of ".\800X_BF_SW\COMMON\atv_common.h")
      } ATV_ERR;
".\800X_BF_SW\APP\8002_AVR\VSP\app_vsp.c", line 609: cc0188: {D} warning:
          enumerated type mixed with another type
              TimingResult = ADIAPI_RepRxGetDetectedTiming (SyncInfo);
".\800X_BF_SW\APP\8002_AVR\VSP\app_vsp.c", line 1309: cc0147:  error:
          declaration is incompatible with
          "void VspApp_SplitterEdidMergeEnable(ATV_ERR, UCHAR, UCHAR)"
          (declared at line 113 of ".\800X_BF_SW\APP\8002_AVR\VSP\app_vsp.h")
  void VspApp_SplitterEdidMergeEnable (ATV_ERR Enable, BOOL UseDefault, BOOL UseVga)
10 errors detected in the compilation of ".\800X_BF_SW\APP\8002_AVR\VSP\app_vsp.c".
cc3089: fatal error: Compilation failed
Tool failed with exit/exception code: 1.
Build was unsuccessful.
Message was edited by: Chris Lott (corrected directory name)
