nanoDAC - Which DACs should be used for open loop systems and which DACs should be used in closed loop systems?
Question asked by Padraic Employee on Apr 15, 2011
It must be stressed that depending on the application performance requirements, all nanoDACs can be used in both open and closed loop systems.
In an open loop application the DAC drives the load (a valve or an actuator, for example) directly while in a closed loop control system an ADC is in the feedback loop controlling the valve/actuator position. This type of control places different requirements on the controlling DAC.
In closed loop applications DAC resolution is more important than accuracy as the ADC provides the accuracy - therefore we pay less attention to INL.
Offset and gain errors can be calibrated out using software adjustment. Extra resolution is typically used in calibration of offset and gain errors.
Products include: AD566X, AD564X, AD562X offering 12/14/16 bits resolution, monotonicity and 12-bit accuracy.
As we said previously, in an open loop application the DAC drives the load (valve, actuator) directly.
Monotonicity and resolution, like in closed loop systems, are important but absolute accuracy, because of the lack of feedback, is critical in keeping the DAC output as close a fit as possible to the ideal DAC transfer function. INL(Accuracy) Offset Errors and Gain errors all contribute to the overall total unadjusted error and need to be taken into consideration.
Products in this category provide +/- 1 LSB INL performance at the specified resolution and include the AD5064, AD5060 and AD5541A/42A products.
Part No[i]
Resolution
No. of DACs
Max INL
Interface
Settling Time typ
Package
On-chip
Reference
Pins
SINGLE
AD5040
14
1
±1
SPI
4 μs
SOT-23
8
AD5060
16
1
±1
SPI
4 μs
SOT-23
8
AD5061
16
1
±4
SPI
4 μs
SOT-23
8
AD5062 (unbuffered)
16
1
±1
SPI
4 μs
SOT-23
8
AD5063(FB   pin)
16
1
±1
SPI
4 μs
MSOP
10
AD5641
14
1
±4
SPI
6 μs
SC70
6
AD5621
12
1
±1
SPI
6 μs
SC70
6
AD5611
10
1
±0.5
SPI
6 μs
SC70
6
AD5601
8
1
±0.5
SPI
6 μs
SC70
6
AD5622
12
1
±2
I2C
6 μs
SC70
6
AD5612
10
1
±0.5
I2C
6 μs
SC70
6
AD5602
8
1
±0.5
I2C
6 μs
SC70
6
AD5680
18
1
±64
SPI
80 μs
SOT-23
8
AD5660
16
1
±16
SPI
8 μs
SOT-23, MSOP
8
AD5662 (FB pin)
16
1
±16
SPI
8 μs
SOT-23, MSOP
8
AD5640
14
1
±4
SPI
8 μs
SOT-23, MSOP
8
AD5620
12
1
±1
SPI
8 μs
SOT-23, MSOP
8
DUAL
AD5667
16
2
±12
I2C
4 μs
LFCSP, MSOP
10
AD5627
12
2
±1
I2C
3 μs
LFCSP, MSOP
10
AD5667R
16
2
±12
I2C
4 μs
LFCSP, MSOP
1.25V/2.5V
10
AD5647R
14
2
±4
I2C
3.5 μs
LFCSP, MSOP
1.25V/2.5V
10
AD5627R
12
2
±1
I2C
3 μs
LFCSP, MSOP
1.25V/2.5V
10
AD5663
16
2
±12
SPI
4 μs
LFCSP, MSOP
10
AD5663R
16
2
±16
SPI
4 μs
LFCSP, MSOP
1.25V/2.5V
10
AD5643R
14
2
±4
SPI
3.5 μs
LFCSP, MSOP
1.25V/2.5V
10
AD5623R
12
2
±1
SPI
3 μs
LFCSP, MSOP
1.25V/2.5V
10
QUAD
AD5064
16
4
±1
SPI
5.8 μs
TSSOP
14,16
AD5044
14
4
±1
SPI
5.8 μs
TSSOP
14,16
AD5024
12
4
±1
SPI
5.8 μs
TSSOP
14,16
AD5066 (unbuffered)
16
4
±1
SPI
7.5 μs
TSSOP
16
AD5664
16
4
±12
SPI
4 μs
MSOP, LFCSP
10
AD5624
12
4
±1
SPI
3 μs
MSOP, LFCSP
10
AD5664R
16
4
±16
SPI
4 μs
MSOP, LFCSP
1.25V/2.5V
10
AD5644R
14
4
±4
SPI
3.5 μs
MSOP, LFCSP
1.25V/2.5V
10
AD5624R
12
4
±1
SPI
3 μs
MSOP, LFCSP
1.25V/2.5V
10
QUAD
AD5665
16
4
±16
I2C
4 μs
LFCSP,  TSSOP
10/14
AD5625
12
4
±1
I2C
3 μs
LFCSP,  TSSOP
10/14
AD5665R
16
4
±16
I2C
4 μs
LFCSP,  TSSOP
1.25V/2.5V
10/14
AD5645R
14
4
±4
I2C
3.5 μs
LFCSP,  TSSOP
1.25V/2.5V
10/14
AD5625R
12
4
±1
I2C
3 μs
LFCSP,  TSSOP
1.25V/2.5V
10/14
OCTAL
AD5678
12/16
8
±1/±16
SPI
6 μs
TSSOP
1.25V/2.5V
14/16
AD5668
16
8
±16
SPI
2.5 μs
TSSOP, LFCSP
1.25V/2.5V
16
AD5648
14
8
±4
SPI
2.5 μs
TSSOP, LFCSP
1.25V/2.5V
14
AD5628
12
8
±1
SPI
2.5 μs
TSSOP, LFCSP
1.25V/2.5V
12
AD5669R
16
8
±16
I2C
2.5 μs
TSSOP. LFCSP
1.25V/2.5V
16
AD5629R
12
8
±1
I2C
2.5 μs
TSSOP, LFCSP
1.25V/2.5V
16
[i] All of our AD56xx products have less that +/- 1 LSB DNL and are monotonic
