AD9914 not writing SPI to registers / AD9914 questions for a newbie
Question asked by Hobbes on Jul 7, 2015
Latest reply on Jul 10, 2015 by sitti
Hi, so i'm fairly new to using this board and the beaglebone black that i'm using to program it over SPI, however I believe what i'm doing is correct so far and am looking for where i've gone wrong. At the moment i'm feeding the board a 32 MHz signal to CLK IN and reading out a 2 MHz signal from the SYNCCLK, which confuses me as I thought the division was by 4 not 16, so there's a first question. The state of the pins are as follows:
MPI00: tied to ground
MPI01: connected to beaglebone's SPIO_SCLK
MPI02: connected to beaglebone's SPIO_D1
SYNC_IO_BUF / IOUPDATE_BUF / RESET_BUF all connected to GPIO pin's 12,14, and 16 on the beaglebone
Function pins IOCFG0-3 tied to state 1000
EXTPDCTL_BUF and OSK_BUF tied to ground
PS0 - PS2 tied to ground (profile zero selected)
P203 P204 and P205 all disabled
providing 3.3v and 1.8v to P300
So with that, here's my python code, at the moment my goal is merely to write to the board data that will
1: enable profile mode
2: set the FTW on channel 0 (to 8MHz if I remember correctly)
import Adafruit_BBIO.GPIO as GPIO
from Adafruit_BBIO.SPI import SPI
import time
spi = SPI(0,0)
spi.lsbfirst = False
spi.mode = 1
spi.msh = 1000000
spi.cshigh=False
spi.loop=False
#sets up reset and ioupdate pins, setting them to low
GPIO.setup("P8_12", GPIO.OUT) #reset pin, yellow
GPIO.setup("P8_14", GPIO.OUT) #IOupdate pin, green
GPIO.setup("P8_16", GPIO.OUT) #SyncIO pin, white
GPIO.output("P8_12", GPIO.LOW)
GPIO.output("P8_14", GPIO.LOW)
GPIO.output("P8_16", GPIO.LOW)
#sends IOupdate pulse
def sendIOupdate():
        GPIO.output("P8_14", GPIO.HIGH)
        time.sleep(0.00001)
#sends reset pulse
def sendReset():
        GPIO.output("P8_12", GPIO.HIGH)
        time.sleep(0.00001)
#sends syncIO pulse
def sendSyncIO():
        GPIO.output("P8_16", GPIO.HIGH)
        time.sleep(0.001)
sendReset()
#Establishes profile mode:
spi.writebytes([0x01,0x09,0x80,0x00,0x00])
sendIOupdate()
#Sets profile 0's FTW
spi.writebytes([0x0B,0x00,0x10,0x62,0x4D])
sendIOupdate()
Running this script of course yields nothing out of the DAC output which is my current issue. I've also altered to data written to disable the SYNC_CLK (writing 0x01,0x00,0x00,0x00,0x00 and sending an IOupdate) which I assumed would disable the sync clock output of 2MHz that I was seeing, however it continued. Leading me to believe I am unable to write data to the board at all. The issue could be with my use of Adafruit's SPI library but I'm unsure. Any and all help is welcome!
Additionally here are some oscilloscope outputs:
1: The SPIO_SCLK and SPIO_D1 outputs from the beaglebone (first call of writebytes) I accidentally left the probe attenuation at 1x here ignore the low voltage values
http://i.imgur.com/WSkCHFZ.png
2: Same thing, but for the second call of writebytes
http://i.imgur.com/HXh14CB.png
As this data looks correct as far as I can tell i'm assuming i'm using SPI at least somewhat properly.
There are IOupdates being called as well but the red pitaya im using as an oscilloscope only has two inputs.
