ADE7953 with CT connection
Question asked by Lyncheese on Jul 6, 2015
Latest reply on Jul 27, 2015 by Lyncheese
Could anyone provide me a guide in how to connect the ADE7953, if I want to use CT as the current sensor, please ?
I need to know which jumper will be closed/opened to make my own board based from the jumper configuration.
I ever ask about the connection with the Shunt, it works and the AN-1118 and AN-639 are quite helpful.
But, there is no single figure for the single phase using the CT.
So far, I just know how to calculate the Burden Resistor for the CT and I will need the phase and gain calibration.
I also have been looking at this thread :
      https://ez.analog.com/message/200762#200762
But, I'm afraid our application is different and the configuration of the components will be different.
In my application, I just want to use the CT as the sensor to replace the previous Shunt to make it a non-invasive sensor.
I don't know anything about the CT.
So, I have some questions regarding to the CT :
     *What is the differences, If I attached the CT at neutral or phase ?
     *Can I used differential voltage configuration or single-ended configuration wth CT ?
          I prefer the single-ended because of it's simplicity, but I dont know whether I could used it using CT.
     *Another question is (outbox of CT) :
          From my experience using the ADE7953 with Shunt. I have to know which one the Phase and which one the neutral,
          when I plug it to my wall socket.
          So, If I plug it in a wrong direction I believe the ADE7953 won't works.
          Any advice in How to solve this problem ?
          So, when people use my device, they don't need to care which one is the Phse/Neutral on their wall socket.
Thank you.
Warm regards.
