AD9889B video do not output on the HDMI interface
Question asked by zcliang on Apr 8, 2011
Latest reply on Apr 21, 2011 by zcliang
input source is a 720x576p picture.And ad9889 has detected the source format.
here is the read back i2c value:
                       0 : 0 0 0 0 0 0 0 0 0 0 1 e 3c 18 1 13
[   14.435517] 10 : 25 37 0 0 0 0 0 8 8 0 0 0 0 0 0 0
[   14.474718] 20 : 0 0 8 0 0 0 0 0 0 0 0 0 8 0 0 0
[   14.513889] 30 : 0 0 0 0 0 0 0 0 0 0 0 81 0 11 44 0
[   14.553328] 40 : 0 10 60 7e 78 80 4 80 0 0 0 0 0 0 0 0
[   14.593007] 50 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[   14.632067] 60 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[   14.671186] 70 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[   14.710196] 80 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[   14.749296] 90 : 0 0 0 0 e0 0 e0 0 3 2 0 18 38 61 10 0
[   14.788833] a0 : 0 0 84 84 8 4 0 0 0 0 0 40 0 0 40 6
[   14.828339] b0 : 14 be 81 f1 24 2 16 5d 10 0 40 ff 0 0 0 0
[   14.868231] c0 : 0 0 0 0 0 0 14 0 1
The value of reg 0x3d 0x3e  said that the vid is 576p.
but bit[0] of 0xc6 seem that TDMS is not enabled , also I can't
see output on the TV.
The following is my init code:
1) set av mute
    reg 0xa1  set bit 2 ~ 5
    reg 0x45  bit 7-6 set 01
2) power on
   reg 0x41   set 0x10
3) default val
   reg 0xa   clr  bit 4 5
   reg 0x98   set 0x03
   reg 0x9c   set 0x38
   reg 0x9d   bit1-0 set 01
   reg 0xa2   set 0x84
   reg 0xa3   set 0x84
   reg 0xbb   set 0xff
4) set clock delay
   reg 0xba  bit7 6 5 set 010
5)set video format tation
   reg 0x47 bit7-4   set 1000
6)video format
   reg 0x15  bit3-1  set 000    rgb444 format
   reg 0x16   set 0x00           output rgb444
   reg 0x17  clr bit 1              4:3 input
   reg 0x45   clr bit 4 5           output rgb
7)csc mode
  reg 0x18 ~ 0x30 rgb_rgb
  reg 0x17  bit 5 4   set 01
  reg 0x3b  bit 0      set 1
8)sellect hdmi mode
  reg 0xaf bit1 set 1
               bit4 clr  0  disable enc
9)clear av mute
   reg 0xa1 bit 5 4 3 2 clr 0
   reg 0x45 bit 7 6 set 10
What's wrong on it ?
zcliang
