Transmit data by KIT KC705 + FMCOMMS2 using ADI IIO Oscilloscope software
Question asked by Thang on Jul 2, 2015
Latest reply on Jul 20, 2015 by larsc
Hi everybody,
I am planning to built a system which consists of KINTEX 7 KC705 and FMCOMMS2 to transmit my LTE_10M data and I want my cellphone can be received this data.
First, I use the Bitfile and Linux ELF image, which are downloaded from the follow link (http://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/quickstart/microblaze ), programming into KIT KINTEX KC705 connected to FMCOMMS2.
Then, I use the ADI IIO Oscilloscope software to load LTE_10M data file into KIT KC705 and transmit data by KIT FMCOMMS2. The parametters of TX path are set up as image 1.
Now, I only measure the transmitted signal on SIGNAL ANALYZE of R&S as seen the attached LTE10Mhz_40Mhz clock image.
Could you please show me how to built the system to make my cellphone receive LTE_10M signal from antenna?
I think I will loop the LTE_10M data (about 1000 times) until my cellphone can be received data. Is it ok?
Sincerely,
Thang
