EVAL-ADV7401EBZ VGA(RGB) => HDMI
Question asked by Michal_S on Jun 26, 2015
Latest reply on Jun 29, 2015 by mattp
Hi everyone
I have a problem with conversion RGB Graphics Input to HDMI output... Do you now how set register in ADV7401? This is my script but is something bad in it:
##TEST SCRIPT##
:RGB -> HDMI:
42 05 02 ; Prim_Mode =010b for GR
42 06 0C ; VID_STD=1100b for 1024x768 _@ 60
42 1D 47 ; Enable 28MHz Crystal
42 3A 21 ; set latch clock settings to 010b, Power Down ADC3
42 3B 80 ; Enable External Bias
42 3C 5D ; PLL_QPUMP to 101b
42 6A 00 ; DLL Phase Adjust
42 6B C2 ; Swap Pr & Pb
42 73 90 ; Set man_gain
42 7B 1D ; TURN OFF EAV & SAV CODES Set BLANK_RGB_SEL
42 85 03 ; Enable DS_OUT
42 86 0B ; Enable stdi_line_count_mode
42 F4 3F ; Max Drive Strength
42 0E 80 ; ADI Recommended Setting
42 52 46 ; ADI Recommended Setting
42 54 00 ; ADI Recommended Setting
42 0E 00 ; ADI Recommended Setting
74 FD FD ; Power up HDMI TX; bus expander
7A 41 12 ; Power up
7A 01 03 ; 20N bytes of CTS audio Clk
7A 03 18 ; 20N bytes of CTS audio Clk
7A 0A 64 ; Mclk setup,Refresh rate settings.
7A 0C 0C ; I2S Setup, Format
7A 15 01 ; RGB 24 bit
7A 16 01 ;
7A 17 08 ; CSC coeffients +-2 (8192_8190)
7A 44 F8 ; SPDIF enable
7A 45 C0 ; Clear AV Mute
7A 46 04 ; Aspect Ratio 16_9
7A 50 60 ; Audio Channel Count
7A 51 90 ; Speaker mapping
7A 96 20 ; Interrupt action for VS
7A 98 03 ; RSVD
7A 9E 10 ; RSVD
7A A0 00 ; RSVD
7A AF 06 ; set HDMI Mode
7A BA E0 ; Input Video clk(negedge)
7A CB 01 ; RSVD
74 F5 F5 ; Power down DAC (Bus expander address may vary by board)
54 00 13 ; Power down Encoder
End
