Update to 2014_R2-2015_04_24.img.xz result no HDMI output
Question asked by fivepanda on Jun 18, 2015
Latest reply on Jun 23, 2015 by fivepanda
Hello everybody!
I have problem on building new 2014_R2-2015_04_24 image to zc706 board(with fmcomms6 card), and now I want someone can geive some help!
The problem discription:
1.     I followed the guide Zynq & Altera SoC Quick Start Guide [Analog Devices Wiki] , downloaded the 2014_R2-2015_04_24 image files,
        I have a 8GB SD card, then I followed the script Linux Download and setting up the image [Analog Devices Wiki] , on my
        pc(ubuntu), the SD card mount as /dev/sdb, so I changed /dev/mmcblk0 to /dev/sdb, is that right?
2.     After step1, I have img copied to SD card, compared to earlier img , the linaro rootfs seems missed a selinuxfs file, is it correct?
       I copied the fmcomms6 bootrom to fat32 partition, now I had all things get ready!
3.     Plug the SD card into the board, then I launch the board, linux boots up, from the serail I can see linux command line works well.
        But HDMI has no output, the boot command output is as follows:
380 bytes read in 9 ms (41 KiB/s)
Loaded environment from uEnv.txt
Importing environment from SD ...
Running uenvcmd ...
Copying Linux from SD to RAM...
reading uImage
3427856 bytes read in 313 ms (10.4 MiB/s)
reading devicetree.dtb
13394 bytes read in 30 ms (435.5 KiB/s)
reading uramdisk.image.gz
** Unable to read file uramdisk.image.gz **
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.19.0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3427792 Bytes = 3.3 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x2a00000
   Loading Kernel Image ... OK
   Loading Device Tree to 1fff9000, end 1ffff451 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 3.19.0 (root@ubuntu) (gcc version 4.6.3 (Sourcery CodeBench Lite 2012.03-79) ) #1 SMP PREEMPT Wed Jun 17 09:47:47 CST 2015
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Xilinx Zynq ZC706
bootconsole [earlycon0] enabled
cma: Reserved 128 MiB at 0x38000000
Memory policy: Data cache writealloc
PERCPU: Embedded 9 pages/cpu @eefd5000 s7552 r8192 d21120 u36864
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260624
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 901604K/1048576K available (4385K kernel code, 265K rwdata, 1716K rodata, 208K init, 132K bss, 15900K reserved, 131072K cma-reserved, 139264K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc05fd798   (6102 kB)
      .init : 0xc05fe000 - 0xc0632000   ( 208 kB)
      .data : 0xc0632000 - 0xc06747c0   ( 266 kB)
       .bss : 0xc06747c0 - 0xc06958ac   ( 133 kB)
Preemptible hierarchical RCU implementation.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
slcr mapped to f0006000
zynq_clock_init: clkc starts at f0006100
Zynq clock init
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 1207951633ns
timer #0 at f0008000, irq=16
Console: colour dummy device 80x30
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x422d48 - 0x422da0
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ps7-ocm: ZYNQ OCM pool: 256 KiB @ 0xf0080000
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource ttc_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.ps7-dma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001000.uart: ttyPS0 at MMIO 0xe0001000 (irq = 20, base_baud = 3125000) is a xuartps
郼onsole [ttyPS0] enabled
console [ttyPS0] enabled
bootconsole [earlycon0] disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f0072000
[drm] Initialized drm 1.1.0 20060810
drivers/gpu/drm/adi_axi_hdmi/axi_hdmi_drv.c:axi_hdmi_platform_probe[176]
platform 70e00000.axi_hdmi: Driver axi-hdmi requests probe deferral
brd: module loaded
loop: module loaded
m25p80 spi32765.0: found s25fl128s, expected n25q128a11
m25p80 spi32765.0: s25fl128s (32768 Kbytes)
5 ofpart partitions found on MTD device spi32765.0
Creating 5 MTD partitions on "spi32765.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000540000 : "config"
0x000000540000-0x000000fc0000 : "image"
0x000000fc0000-0x000002000000 : "spare"
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 33
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 3
pca953x 4-0021: interrupt support not compiled in
i2c i2c-0: Added multiplexed i2c bus 4
rtc-pcf8563 5-0051: chip found, driver version 0.4.3
rtc-pcf8563 5-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
at24 7-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
zynq-edac f8006000.ps7-ddrc: ecc not enabled
Xilinx Zynq CpuIdle Driver started
Driver 'mmcblk' needs updating - please use bus_type methods
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-arasan e0100000.sdhci: No vmmc regulator found
sdhci-arasan e0100000.sdhci: No vqmmc regulator found
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
si570 1-005d: registered, current frequency 156250000 Hz
platform 79020000.axi-ad9652-lpc: Driver cf_axi_adc requests probe deferral
spi spi32766.1: Driver ad9467 requests probe deferral
mmc0: new high speed SDHC card at address 0002
mmcblk0: mmc0:0002 00000 7.41 GiB
mmcblk0: p1 p2 p3
ad9517 spi32766.0: probed
spi32766.2 supply vcc not found, using dummy regulator
adv7511-hdmi-snd fpga-axi@0:adv7511_hdmi_snd: adv7511 <-> 75c00000.axi-spdif-tx mapping ok
TCP: cubic registered
Registering SWP/SWPB emulation handler
usb 1-1: new low-speed USB device number 2 using ci_hdrc
Console: switching to colour frame buffer device 170x48
axi-hdmi 70e00000.axi_hdmi: fb0:  frame buffer device
axi-hdmi 70e00000.axi_hdmi: registered panic notifier
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 on minor 0
input: Generic USB K/B as /devices/soc0/amba@0/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1:1.0/0003:13BA:0017.0001/input/input0
oooooooo|ooooooo-----------------
  DCO 0x7 CLK 250000000 Hz
cf_axi_adc 79020000.axi-ad9652-lpc: ADI AIM (8.00.b) at 0x79020000 mapped to 0xf05e0000, probed ADC AD9652 as MASTER
input: gpio_keys as /devices/soc0/gpio_keys/input/input1
hid-generic 0003:13BA:0017.0001: input,hidraw0: USB HID v1.10 Keyboard [Generic USB K/B] on usb-ci_hdrc.0-1/input0
rtc-pcf8563 5-0051: setting system clock to 1970-02-04 17:31:35 UTC (3000695)
input: Generic USB K/B as /devices/soc0/amba@0/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1:1.1/0003:13BA:0017.0002/input/input2
ALSA device list:
  #0: HDMI monitor
hid-generic 0003:13BA:0017.0002: input,hidraw1: USB HID v1.10 Mouse [Generic USB K/B] on usb-ci_hdrc.0-1/input1
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 208K (c05fe000 - c0632000)
Mount failed for selinuxfs on /sys/fs/selinux:  No such file or directory
* Setting up X socket directories...       tropy available              [ OK ]
* Starting IIO Daemon iiod                                              [ OK ]
Last login: Wed Feb  4 17:27:44 UTC 1970 on tty1
Welcome to Linaro 14.04 (GNU/Linux 3.19.0 armv7l)
* Documentation:  https://wiki.analog.org/ https://ez.analog.com/
     Then I manually input "startx":
xauth:  file /root/.Xauthority does not exist
X.Org X Server 1.15.1
Release Date: 2014-04-13
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-58-highbank armv7l Ubuntu
Current Operating System: Linux analog 3.19.0 #1 SMP PREEMPT Wed Jun 17 09:47:47 CST 2015 armv7l
Build Date: 16 April 2014  01:41:53PM
xorg-server 2:1.15.1-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.30.2
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Wed Feb  4 17:32:02 1970
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
setversion 1.4 failed: Permission denied
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension SELinux
Initializing built-in extension XFree86-VidModeExtension
Initializing built-in extension XFree86-DGA
Initializing built-in extension XFree86-DRI
Initializing built-in extension DRI2
Loading extension GLX
shuto^Hd^H^Hddd^Cxinit: connection to X server lost
Before post this question , I googled and search on the EZONE, unfortunately find no exact answers...
Anyone can give help?@
