Internal flash memory access with Timers enabled on pin PG13 and PG14?
Question asked by mauri1106 on Apr 4, 2011
Latest reply on Apr 18, 2011 by mauri1106
     in my application I use  BF518F DSP and I want to use only internal flash memory to store code and data.
I need to use TMR0 and TMR1 also, to generate 2 differents PWM patterns on the respective output pins.
In my Hardware configuration i must use PG13 and PG14 for Timers, but my doubt is that these pin are shared with SPI0 (used for internal Flash Memory).
Note that I don't need to use SPI0 for other purpose except to access internal flash memory.
Are there some problem with this configuration?
Can I use PG13 and PG14 for Timers without compromise Internal Flash Memory read/write access?
Thanks a lot for your help
Maurizio
