Packet Mode of ADF7023
Question asked by JayRocks on Apr 1, 2011
Latest reply on Jun 10, 2011 by SteveH
Hello!!
I would like to ask about the Packet Mode of ADF7023.
My  aim is to transmit voice. The voice will be converted into a signal  using a Microphone and then I will use an ADC to have a digital stream  of bits. With this digital stream, which will be the input of the  transceiver (working as transmitter), I would like to transmit it via  radio with ADF7023 and, on the other side, I want to receive this signal  with a receiver (also a ADF7023).
In order to do that, I am planning to use the Packet Mode (*) of ADF7023
My first question is:
Is it possible to use packet mode to transmit real time data (voice)? If yes, which pin should I use to input the data?
I  know there is a Packet Ram, that can be configured from the SW of  ADF7023 but it seems that it is only possible to write data manually.
(*) I have chosen Packet Mode instead of Sport Mode because I need to  configure the receiver to qualify packets based on address match (I need  to communicate with more than one receiver), and reading the datasheet  my impression is that I can only use the option "address match" if I use  packet mode.
My second question is:
Am I wrong?
Is it also possible to configure the receiver to qualify packets based on address match with SPORT MODE?
I am looking forward to hearing from you.
Thank you very much in advance.
J.
