ADV7188 configuration - Y/C in AIN1 and AIN4
Question asked by vishnudeep on Mar 30, 2011
Latest reply on Apr 5, 2011 by vishnudeep
Hello all,
    I want to configure ADV7188 to accept Y/C on AIN1 and AIN4 channels in 10 bit mode. This is the script that I
obtained from this forum. Are all this registers required? becoz ADV7183 needed only a few registers to be configured.
In the below script first line , does 42 indicate the slave address, 03 the register address and 00 the data?
What change need be made to the below script to meet my requirements?
##SDP Y/C##
:AUTODETECT NTSC/PAL/SECAM Y/C In 10 Bit 422 Out through Encoder (Autodetect Enable):
42 03 00 ; 10 Bit Mode
42 04 57 ; Enable SFL
42 1D 47 ; Enable 28MHz Crystal
42 31 02 ; Clears NEWAV_MODE, SAV/EAV  to suit ADV video encoders
42 3A 13 ; Set Latch Clock & turn off ADC2 & ADC3
42 3B 71 ; IBIAS ADJUST
42 3D A2 ; MWE Enable Manual Window, Colour Kill Threshold to 2
42 3E 6A ; BLM optimisation
42 3F A0 ; BGB
42 69 03 ; Sets SDM_SEL to 03 for YC/CVBS Auto   Ain 11 , Ain 12
42 c3 32 ; Manually Mux Y/AIN2 to ADC0,C/AIN3 to ADC1
42 C4 FF ; Manual mux enable
42 F3 03 ; Enable Anti Alias Filters on ADC0 & ADC1
42 F9 03 ; Set max v lock range
42 0E 80 ; ADI Recommended Write
42 52 46 ; ADI Recommended Write
42 54 00 ; ADI Recommended Write
42 7F FF ; ADI Recommended Write
42 81 30 ; ADI Recommended Write
42 90 C9 ; ADI Recommended Write
42 91 40 ; ADI Recommended Write
42 92 3C ; ADI Recommended Write
42 93 CA ; ADI Recommended Write
42 94 D5 ; ADI Recommended Write
42 B1 FF ; ADI Recommended Write
42 B6 08 ; ADI Recommended Write
42 C0 9A ; ADI Recommended Write
42 CF 50 ; ADI Recommended Write
42 D0 4E ; ADI Recommended Write
42 D1 B9 ; ADI Recommended Write
42 D6 DD ; ADI Recommended Write
42 D7 E2 ; ADI Recommended Write
42 E5 51 ; ADI Recommended Write
42 0E 00 ; ADI Recommended Write
54 17 02 ; Software Reset
54 00 FC ; Power up all Dacs & PLL
54 01 80 ; SD Mode only, Data input on Y-Bus
54 80 10 ; SAF Luma filter enabled, NTSC mode
54 82 C9 ; Step control on, pixel data valid, pedestal on, PrPb SSAF on,CVBS/YC out
54 84 06 ; Enable SFL
54 88 10 ; Pix10 Enable
54 87 60 ; PAl/NTSC auto-detect enabled
End
Any help in this matter is highly appreciated.
Deepa.
