Xtal 28.6363MHz for ADV7180.
Question asked by Tamu on Jun 15, 2015
Latest reply on Jun 21, 2015 by Tamu
I have a question about Xtal 28.6363MHz for ADV7180.
The spec of "Frequency Stability" is max. plus-minus 50ppm on the data sheet.
Xtal "HC-49" is used on your evaluation board.
The spec of HC-49 says "Frequency Tolerance" = plus-minus 30ppm or 50ppm and "Frequency Stability" = plus-minus 50ppm.
So there seems to be two kind of devices. It means "Frequency Tolerance" = plus-minus 30ppm or 50ppm.
Question:
Should we use Xtal which "Frequency Tolerance" is plus-minus 30ppm?
Or can we use both of "Frequency Tolerance" plus-minus 30ppm and 50ppm?
Thank you!
Best regards.
