file export memory refresh
Question asked by genp on Mar 28, 2011
Latest reply on Mar 29, 2011 by BrettG
please, urgently need memory refreshing on the file export.
I worked with the ADU1446 last year, succesfully exported files and implemented them in a microcontroller project.
In the _IC_1.h of the last year project I see the parameter RAM definitions and array:
#define PARAM_SIZE 564
#define PARAM_ADDR 0
ADI_REG_TYPE Param_Data[PARAM_SIZE] = {
Also it was a function in the default_download() of this file:
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_IC_1, PARAM_ADDR, PARAM_SIZE, Param_Data );
When I export files now, I don't see the parameter RAM definitions and array (and can't find them anywhere).
Also, instead of the above function there is:
SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_IC_1, _ADDR, _SIZE, _Data );
and compiler complains that _ADDR, _SIZE and _Data are not defined.
Even more, when I export the files for the last year project with the version of SigmaStudio I used that time,
I get the same results as now.
What am I missing ?
