AD9361 2rx/2tx timing
Question asked by cy92612 on Jun 12, 2015
Latest reply on Dec 17, 2015 by charlie_m
I'm using the 2R/2T mode and the 2R/2T timing.  But, I'm getting I/Q data swapped for some reason.  I have timing closure in the FPGA, and I am receiving data reliably.  I'm using the PRBS test mode to check these things step by step.
I set up the PRBS test mode with channel 2 I/Q masked + channel 1 Q masked. Register 0x3f4 = 0x09, 0x3f6 = 0x38.  I expect to see channel #1 I data with the PRBS sequence.  What I see is 0's for I and data for Q.  However, the Q data is following the expected PRBS sequence for I.  Putting a scope on the PCB, I see RX data switching on the falling edge of DATA_CLK.  It should be rising edge for I data and falling for Q data.
I can repeat the test with channel #1 I masked and I see the opposite results.  There is something missing here, that I haven't been able to figure out.  Does anyone have suggestions?  Is the datasheet correct?
Chris
