Problem with UART receive/transmit data
Question asked by BlueIceScream on Mar 27, 2011
Latest reply on Mar 29, 2011 by WassimB
Hello all.
i want do simple data receive and transmit project from UART device.
For this i use uart device driver. i write code but it don't work. I set breakpoint in callback function and send data from PC. My program in debug mode don't stop in breakpoint so it never call my callback function. When i test other application (uart loopback example) all work right.
Please say where i have mistake.
#include <drivers/uart/adi_uart.h>
// Buffers count
#define ELEMENT_COUNT               (8) // 8 byte
#define ELEMENT_WIDTH                (1) // 1 byte
#define STOP_BITS_COUNT            (1)
#define BAUD_RATE                     (9600)
#define PARITY                         (FALSE)
#define DATA_BITS_COUNT               (8)
void UART_Reset();
static void UART_WriteData(unsigned char * data,unsigned char len);
void UARTCallbackFunction(void *ClientHandle, u32 Event, void *pArg);
static u8                    UARTInboundData[ELEMENT_COUNT];
static u8                    UARTOutboundData[ELEMENT_COUNT/2];
static ADI_DEV_1D_BUFFER     UARTInboundBuffer;
static ADI_DEV_1D_BUFFER     UARTOutboundBuffer;
static ADI_DEV_DEVICE_HANDLE UARTHandle;
extern void ProcessCommandFromTube();
/*     Function: Reset UART
/*     Description: reset uart device and config it
void UART_Reset()
u32                    i;
u32                        Result;
ADI_DEV_CMD_VALUE_PAIR UARTConfiguration[] = {
{ ADI_DEV_CMD_SET_DATAFLOW_METHOD,      (void *)ADI_DEV_MODE_CHAINED },
{ ADI_UART_CMD_SET_DATA_BITS,           (void *)DATA_BITS_COUNT      },
{ ADI_UART_CMD_ENABLE_PARITY,           (void *)PARITY                  },
{ ADI_UART_CMD_SET_STOP_BITS,           (void *)STOP_BITS_COUNT      },
{ ADI_UART_CMD_SET_BAUD_RATE,           (void *)BAUD_RATE              },
{ ADI_DEV_CMD_END,                       NULL                            },
Result = adi_dev_Open(DevMgrHandle,&ADIUARTEntryPoint,0, (void *)0x12345,&UARTHandle,
               ADI_DEV_DIRECTION_BIDIRECTIONAL, NULL, NULL, UARTCallbackFunction);
Result = adi_dev_Control(UARTHandle,ADI_DEV_CMD_TABLE,UARTConfiguration);
UARTInboundBuffer.Data              = InboundData;
UARTInboundBuffer.ElementCount      = ELEMENT_COUNT;
UARTInboundBuffer.ElementWidth      = ELEMENT_WIDTH;
UARTInboundBuffer.CallbackParameter = (void *)0;
UARTInboundBuffer.pNext             = NULL;
UARTInboundBuffer.pAdditionalInfo   = (void *)0;
UARTOutboundBuffer.Data              = OutboundData;
UARTOutboundBuffer.ElementCount      = ELEMENT_COUNT/2;
UARTOutboundBuffer.ElementWidth      = ELEMENT_WIDTH;
UARTOutboundBuffer.CallbackParameter = (void *)1;
UARTOutboundBuffer.pNext             = NULL;
UARTOutboundBuffer.pAdditionalInfo   = (void *)0;
Result = adi_dev_Read(UARTHandle,ADI_DEV_1D, (ADI_DEV_BUFFER *)&UARTInboundBuffer);
Result = adi_dev_Control(UARTHandle,ADI_DEV_CMD_SET_DATAFLOW, (void *)TRUE);
/*     Function: UART_WriteData
/*     Description: write data to uart device
unsigned char i;
if (len>ELEMENT_COUNT/2) return;
for (i=0;i<len;i++) UARTOutboundData[i]=data[i];
adi_dev_Write(UARTHandle,ADI_DEV_1D, (ADI_DEV_BUFFER *)&UARTOutboundBuffer);
/*     Function: Callback
/*     Description: Callback for input data
static void UARTCallbackFunction(void *ClientHandle, u32 Event, void *pArg)
char BufferType = (char)pArg;
if ((Event==ADI_DEV_EVENT_BUFFER_PROCESSED)&&(BufferType==0)) ProcessCommandFromTube();
