Using Simulink and Libiio to control DCXO on AD9361
Question asked by Arne_2 on Jun 9, 2015
Latest reply on Jun 10, 2015 by Arne_2
I tried to control the DCXO on the AD9361 via Simulink and the Libiio interface block.
For this purpose, I added the DCXO course and fine tune driver to the "ad9361.cfg" file:
data_in_device = cf-ad9361-dds-core-lpc
data_out_device = cf-ad9361-lpc
ctrl_device = ad9361-phy
channel = RX_LO_FREQ,IN,out_altvoltage0_RX_LO_frequency,
channel = RX_SAMPLING_FREQ,IN,in_voltage_sampling_frequency,
channel = RX_RF_BANDWIDTH,IN,in_voltage_rf_bandwidth,
channel = RX1_GAIN_MODE,IN,in_voltage0_gain_control_mode,
channel = RX1_GAIN,IN,in_voltage0_hardwaregain,
channel = RX1_RSSI,OUT,in_voltage0_rssi,
channel = RX2_GAIN_MODE,IN,in_voltage1_gain_control_mode,
channel = RX2_GAIN,IN,in_voltage1_hardwaregain,
channel = RX2_RSSI,OUT,in_voltage1_rssi,
channel = TX_LO_FREQ,IN,out_altvoltage1_TX_LO_frequency,
channel = TX_SAMPLING_FREQ,IN,out_voltage_sampling_frequency,
channel = TX_RF_BANDWIDTH,IN,out_voltage_rf_bandwidth,
channel = DCXO_Course,IN,dcxo_tune_course,
channel = DXCO_Fine,IN,dcxo_tune_fine,
But when I run this with a modified version of the example file "ad9361_sim.slx", I get the following error message:
An error occurred while running the simulation and the simulation was terminated
MATLAB System block 'ad9361_sim_mod/AD9361/MATLAB System' error occurred when invoking 'stepImpl' method of 'iio_sys_obj'. The error was thrown from '
'D:\Simulink\libiio\hil_models\fmcomms2_3_data_stream\libiio_if.m' at line 651
'D:\Simulink\libiio\hil_models\fmcomms2_3_data_stream\iio_sys_obj.m' at line 263'.
Output argument "ch" (and maybe others) not assigned during call to "libiio_if/findAttribute".
Apparently, DCXO course and fine tune is not available via Libiio.
I did a quick spin over all channels and attributes that are available via function "findAttribute":
Ch#      Attr#       Attr-Name          Attr-Filename
0   0  input                              in_temp0_input
1   0  fastlock_store               out_altvoltage1_TX_LO_fastlock_store
1   1  frequency               out_altvoltage1_TX_LO_frequency
1   2  fastlock_recall               out_altvoltage1_TX_LO_fastlock_recall
1   3  fastlock_load               out_altvoltage1_TX_LO_fastlock_load
1   4  fastlock_save               out_altvoltage1_TX_LO_fastlock_save
2   0  raw               out_voltage2_raw
2   1  scale               out_voltage2_scale
2   2  rf_bandwidth               out_voltage_rf_bandwidth
2   3  rf_port_select_available               out_voltage_rf_port_select_available
2   4  filter_fir_en               out_voltage_filter_fir_en
2   5  sampling_frequency               out_voltage_sampling_frequency
3   0  raw               out_voltage3_raw
3   1  scale               out_voltage3_scale
3   2  rf_bandwidth               out_voltage_rf_bandwidth
3   3  rf_port_select_available               out_voltage_rf_port_select_available
3   4  filter_fir_en               out_voltage_filter_fir_en
3   5  sampling_frequency               out_voltage_sampling_frequency
4   0  raw               in_voltage2_raw
4   1  offset               in_voltage2_offset
4   2  scale               in_voltage2_scale
4   3  gain_control_mode_available               in_voltage_gain_control_mode_available
4   4  sampling_frequency               in_voltage_sampling_frequency
4   5  rf_port_select_available               in_voltage_rf_port_select_available
4   6  bb_dc_offset_tracking_en               in_voltage_bb_dc_offset_tracking_en
4   7  rf_bandwidth               in_voltage_rf_bandwidth
4   8  rf_dc_offset_tracking_en               in_voltage_rf_dc_offset_tracking_en
4   9  quadrature_tracking_en               in_voltage_quadrature_tracking_en
4   10  filter_fir_en               in_voltage_filter_fir_en
5   0  rf_port_select               in_voltage1_rf_port_select
5   1  rssi               in_voltage1_rssi
5   2  hardwaregain               in_voltage1_hardwaregain
5   3  gain_control_mode               in_voltage1_gain_control_mode
5   4  gain_control_mode_available               in_voltage_gain_control_mode_available
5   5  sampling_frequency               in_voltage_sampling_frequency
5   6  rf_port_select_available               in_voltage_rf_port_select_available
5   7  bb_dc_offset_tracking_en               in_voltage_bb_dc_offset_tracking_en
5   8  rf_bandwidth               in_voltage_rf_bandwidth
5   9  rf_dc_offset_tracking_en               in_voltage_rf_dc_offset_tracking_en
5   10  quadrature_tracking_en               in_voltage_quadrature_tracking_en
5   11  filter_fir_en               in_voltage_filter_fir_en
6   0  fastlock_recall               out_altvoltage0_RX_LO_fastlock_recall
6   1  fastlock_store               out_altvoltage0_RX_LO_fastlock_store
6   2  frequency               out_altvoltage0_RX_LO_frequency
6   3  fastlock_load               out_altvoltage0_RX_LO_fastlock_load
6   4  fastlock_save               out_altvoltage0_RX_LO_fastlock_save
7   0  gain_control_mode               in_voltage0_gain_control_mode
7   1  rssi               in_voltage0_rssi
7   2  rf_port_select               in_voltage0_rf_port_select
7   3  hardwaregain               in_voltage0_hardwaregain
7   4  gain_control_mode_available               in_voltage_gain_control_mode_available
7   5  sampling_frequency               in_voltage_sampling_frequency
7   6  rf_port_select_available               in_voltage_rf_port_select_available
7   7  bb_dc_offset_tracking_en               in_voltage_bb_dc_offset_tracking_en
7   8  rf_bandwidth               in_voltage_rf_bandwidth
7   9  rf_dc_offset_tracking_en               in_voltage_rf_dc_offset_tracking_en
7   10  quadrature_tracking_en               in_voltage_quadrature_tracking_en
7   11  filter_fir_en               in_voltage_filter_fir_en
8   0  rf_port_select               out_voltage1_rf_port_select
8   1  hardwaregain               out_voltage1_hardwaregain
8   2  rssi               out_voltage1_rssi
8   3  rf_bandwidth               out_voltage_rf_bandwidth
8   4  rf_port_select_available               out_voltage_rf_port_select_available
8   5  filter_fir_en               out_voltage_filter_fir_en
8   6  sampling_frequency               out_voltage_sampling_frequency
9   0  rssi               out_voltage0_rssi
9   1  rf_port_select               out_voltage0_rf_port_select
9   2  hardwaregain               out_voltage0_hardwaregain
9   3  rf_bandwidth               out_voltage_rf_bandwidth
9   4  rf_port_select_available               out_voltage_rf_port_select_available
9   5  filter_fir_en               out_voltage_filter_fir_en
9   6  sampling_frequency               out_voltage_sampling_frequency
Is there any information available which channels/attributes are accessible via Simulink/Libiio?
Is there anything that I have to change in my Linux setup to make this work?
Regards and thanks in advance,
Arne
