Problem with PCMX TO PCM module and PCM TO PCMX module
Question asked by shaoqin on Jun 3, 2015
Latest reply on Aug 2, 2017 by jinquan
I refer to section 5 of SigmaStudio_for_SHARC_Framework.pdf. When I test PCMX TO PCM module, I can make the macro definition: ENABLE_PCMX_IN.See below
1.PCMX can transmit two channel signal by default,When I test the SSH and found the CH1 no audio output.What's the problem?
2.When I can make a macro definition: ENABLE_PCMX_IN, ENABLE_PCMX_OUT,I tested PCMX TO PCM module and PCM TO PCMX module.See below
When I test the SSH and found the CH0 no audio output.What's the problem?
