AD6657 + HS_ADC_EVALC Problem. Please Help
Question asked by gudduarnav on Jun 3, 2015
Latest reply on Jul 3, 2015 by gudduarnav
Please help me regarding the problem i am facing..... Thank you in advance for your time and effort....
-> I have a EVALC board and a AD6657EBZ baord. Both are connected, powered from respective power adapter, and connected to my PC using USB cable.
->I have P501 connected/shorted, so that I can use Channel A.
->My question is , should I apply clock (Sine wave or Square wave), [I presume Sine Wave,Am I correct?] and the amplitude of clock signal? NOTE:I have a function generator Matravi FG-3000,which Iwant to use as a clock source.
->Second question is -With P501 jumper shorted, is ChannelA enabled? Do I need any further jumper connections?
-> Third question is, what should I do next to capture data. Ihave read the guide, but till now Iam not successful to get data.
->Ihave used VisualAnalog, but still failed.
-> Ihave a custom C# application made to capture data, but it returns 0 data.
-> The important partof code code are:
public string FPGA
            set
                SelectDevice();
                int err = ADIFIFO.FPGAConfigure(value);
                if (err != ADIFIFO.ERR_SUCCESS)
                    StringBuilder sb = new StringBuilder(512);
                    sb.Clear();
                    ADIFIFO.GetErrorMessage(err, sb);
                    throw new IOException(string.Format("Error burning FPGA file {0} [Error Code:#{1} :{2}]", value, err, ADIFIFO.GetErrorMessage(err)));
        public bool Capture(int delay_ms)
            SelectDevice();
            int err = ADIFIFO.FillFIFOs(delay_ms);
            return err == ADIFIFO.ERR_SUCCESS ? true : false;
        public bool ReadSamples(int channels, byte[] buffer, int offset, int length)
            GCHandle hbuffer = GCHandle.Alloc(buffer, GCHandleType.Pinned);
            SelectDevice();
            int err = ADIFIFO.CaptureFIFO_Bytes(hbuffer.AddrOfPinnedObject() + offset, length, (short)channels);
            hbuffer.Free();
The client program is:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Arnav.Quartz.Devices.AnalogDevices.EvalBoard;
namespace EVALC.Demo1
    class Program
        static void Main(string[] args)
            Console.WriteLine("API# {0}", EvalBoard.APIVersion);
            Console.WriteLine("Board Count = {0}", EvalBoard.BoardCount);
            for (int i = 0; i < EvalBoard.BoardCount; i++)
                Console.WriteLine("Device #{0} : {1} [{2}]", EvalBoard.BoardInfo[i].ID, EvalBoard.BoardInfo[i].Name,EvalBoard.BoardInfo[i].Firmware);
            Console.WriteLine();
            try
                EvalBoard b = new EvalBoard(0);
                Console.WriteLine("{0} : {1} [{2}]", b.Info.ID, b.Info.Name, b.Info.Firmware);
                b.FPGA = "AD6657_64k.bin";
                Console.WriteLine("FPGA copied successfully");
                while (!Console.KeyAvailable)
                    Console.WriteLine("Capture = {0}", b.Capture(1000));
                    byte[] buffer = new byte[16 * 1024];
                    Console.WriteLine("Read data={0}", b.ReadSamples(1, buffer, 0, buffer.Length));
                    for (int i = 0; i < buffer.Length; i++)
                        Console.Write("{0}\t", buffer[i]);
                Console.ReadKey();
            catch(Exception ex)
                Console.WriteLine("{0}", ex.Message);
            Console.ReadKey();
-> The code above shows my board information, but captured data printed on screen are all 0. No noise or anything.
->Please guide me through the board setup, so that Ican work atleast with Visual Analog or FIFOInterface.h api.
Thank you all again.
