adxl345 output value(xyz axis) question
Question asked by liliao on Jun 1, 2015
Latest reply on Jun 2, 2015 by liliao
   I used the EVAL-ADXL345Z-M board, satelliate board on table flatly, view meas data by the EVB GUI V1.3.vi , attachment 1.png is the config parameter and xyz realtime output data(about x=-1,y=11,z=238) ,and 2.png is all register value currently.
   Since I program a test project with keil mdk, 4 wire SPI mode, compiler it and burning the hex file to  EVAL-ADXL345Z-M board; keep the adxl345 config parameter same as EVB GUI v1.3.vi, as below:
XL345_DATA_FORMAT  = 0x0b
XL345_BW_RATE          = 0x0a
XL345_POWER_CTL      = 0x08
XL345_INT_ENABLE      = 0x00
XL345_OFSX                 = 0x00
XL345_OFSY                 = 0x00
XL345_OFSZ                 = 0x00
  After burning hex file, I reset the EVAL-ADXL345Z-M board with SW2 button, then adxl345 output data sample as following:
x=-11,y=-1,z=227
x=-12,y=0,z=226
x=-8,y=0,z=223
x=-11,y=0,z=222
x=-10,y=-1,z=225
x=-8,y=-1,z=226
x=-11,y=-1,z=225
  Why my test program output data is different from EVB GUI output data(about x=-1,y=11,z=238)?  Difference value of every Axis is about 10 lsb;
  Please give me some hint,thanks !
