FIR/IIR Accelerator Switching - Buzz
Question asked by larry_o on May 29, 2015
Latest reply on Aug 27, 2015 by Mitesh
I have set up FIR and IIR accelerators on my 21489 EZ Kit, both running correctly in my project individually (one active, other commented out and vice versa).
I believe it is possible to use both in the same project (in sequence) by setting the appropriate bits (17 & 18) in the PMCTL1 register. I have tried doing this, but when I try to switch between accelerators, I get a "buzz" like distortion over the audio signal. Bear in mind that I have both configured correctly, as they both function as expected without distortion when only 1 accelerator is being used.
Here are the functions I am calling to switch accelerators just before the call to each of my FIR and IIR functions within the main process audio loop.
void SelectFIR_Accel()
    int temp;
    //Mapping the FIR DMA interrupt
    temp=*pPICR0;
    temp&=~(P0I0|P0I1|P0I2|P0I3|P0I4);
    temp|=P0I0|P0I1|P0I3|P0I4;
    *pPICR0=temp;
    asm("nop;nop;nop;nop;");
    interrupt(SIG_P0,FIR_ACC_ISR);
    //Selecting the FIR Accelerator
    temp=*pPMCTL1; // --> in previous versions PMCTL_EXT, perhaps have to be changed, if you don't have "def21489.h" and "Cdef21489.h" in the versions according to 2146x Hardware Reference 0.2
    temp&=~(BIT_17|BIT_18);
    temp|=FIRACCSEL;
    *pPMCTL1=temp;
void SelectIIR_Accel()
    int temp, i;
    //Mapping the IIR DMA interrupt
    temp=*pPICR0;
    *pPICR0=temp;
    interrupt(SIG_P0,IIR_ACC_ISR);
    //Selecting the IIR Accelerator
    temp=*pPMCTL1;
    temp|=IIRACCSEL;
    *pPMCTL1=temp;
Any suggestions would be much appreciated.
Thanks
Brian
